01-06-2011, 04:43 PM | #1 |
4x4 conversion
hey i have a 67 c10 stepside and ive always wanted to lift this truck but i want 4x4 too can any one tell me everything i need to do the conversion or give me some builds i can look at
1978 c10 stepside |
01-26-2011, 12:29 AM | #2 |
Re: 4x4 conversion
I wouldn't try it personally. Just too much work. If you do just find a similar year 4x4 chassis.
01-26-2011, 01:07 AM | #3 |
toys'r'us
Re: 4x4 conversion
find a 4x4 frame and drivetrane with the same wheelbase and start swapping some sheet metal
01-26-2011, 01:39 AM | #4 |
Re: 4x4 conversion
Add leaf springs and frame hanger brackets on the frame in the rear and extend the brake lines and park brake cables.
remove all front suspension and engine crossmember. install a 4x4 crossmember, spring hangers and get leaf springs and an axle for the front. Extend and modify brake lines as needed. Get and install a 4x4 steering box and modify the frame as needed. Install a transmission and transfer case, Cut out the floor and put in a high hump floor panel, and get driveshafts as needed. adjust driveline angles. set ride-heights. This is just a Very Very Quick run down of some of the major key points. I know I'm missing a lot of stuff here, like the 2wd driveshaft center support, etc... I just love fabrication work and modifying stuff though. It all depends what you have access to as far as parts and tools, your skill level, etc. If it was me, I'd be all over converting! Ya learn a lot, too.
T.Y.N Custom Works..... Because "Stock" Sucks! 1971 K 10 GMC Long Bed 1977 Formula T/A Frame off Resto-Mod 1995 FXDL Harley Low Rider 1985 C10 ShortWide 91 Burb front. Last edited by Transformula; 01-26-2011 at 01:40 AM. |
01-26-2011, 06:10 PM | #5 | |
Re: 4x4 conversion
id go with the first few guys. fina a 4x4 frame and drive train and start swapping your body over and then lift it. easyest and probably cheapest way to do it in the long run.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains Quote:
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there |
01-27-2011, 01:36 PM | #6 |
Re: 4x4 conversion
Once again Here is a thread to check out for the 4x4 conversion
http://67-72chevytrucks.com/vboard/s...d.php?t=310493 JLT |
02-12-2011, 11:37 AM | #7 |
Newbee
Re: 4x4 conversion
Here is a link to my build. Kind of a readers digest version, but you will get the idea. Its alot of work! You will hate the mere sight of rivets!
http://67-72chevytrucks.com/vboard/s...58#post4464158 |
