01-07-2011, 01:48 PM | #1 |
BIG CHEVY 3600 LONGBOX
Rerouting the cowl vent tube
Has anyone filled in the hole on the firewall where the cowl vent tube runs out and redirected it under the dash and out between the right fender and the inner fender? I have filled the hole and will soon be looking to see the best spot to drill through.
_________________________ http://s729.photobucket.com/home/BIGCHEVY3600/allalbums
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 Last edited by BIG CHEVY 3600; 01-07-2011 at 01:48 PM. |
01-07-2011, 01:52 PM | #2 |
Re: Rerouting the cowl vent tube
I did the same thing, I just have not re-routed the drain hose yet. I was just thinking of drilling the hole somewhere by the tranny tunnel. I wanted to keep the most direct rout from the vent staright down.
But like I said, I still need to do mine. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-07-2011, 02:02 PM | #3 |
I would like to keep the hose as invisable as possible by running it under the dash over to the side and then down only as much as necessary to put it between the inner and outer fenders. I have seen it done that way but can't remember exactly where the hole was drilled.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
01-07-2011, 02:21 PM | #4 |
I like that idea, I would just want to make sure I didn't have any problem with the water backing up our having a harder time to drain.
Plus on mine, I will have a center counsle so I should not have an issue hidding it even if I run it straight down. Marc
