01-07-2011, 06:57 PM | #1 |
Screaming Edlebrock HELP!!
This one if for you edelbrock experts. I have a 350 engine with a 600cfm edelbrock and if I get on the gas good enough the carb will scream like hell as long as I keep my foot on gas. If driving below 60mph the carb is fine but once I get it going just over 60 the carb starts to scream. I've noticed it only started doing that recently as the weather got colder. What is it that I can do to eliminate the screaming sound period besides waiting for SPRING WEATHER!
01-07-2011, 07:00 PM | #2 |
Re: Screaming Edlebrock HELP!!
oh and the sound is pretty close to what it sounds like when belts are screaming/screeching. that's what I thought it was so when I went to check the tension I was suprised to see the belts were fine. thank you guys for your time!
01-07-2011, 07:03 PM | #3 |
Are you running a stock intake as well? Or an edelbrock intake? If you have an adapter it might have a vaccum leak. Mine did it when I first put it on because I didnt tighten it down enough. Screamed like a banshee
01-07-2011, 09:45 PM | #4 |
there is a vacuum bleed on the electric choke mechanism. I've had one whine at idle before.
01-07-2011, 10:16 PM | #5 |
Very simple solution. Remove, buy a new Holley and replace! Seriously had same issue and it was the electric choke as someone said earlier... good luck
01-07-2011, 10:53 PM | #6 |
I built it
if it sounds like air sucking in thats the secondarys starting to open up. usually if its a vac. leak it'll run bad. or try spraying belt dressing on the belts, mine were squellin once and they seemed tight, but i sprayed em with the dressing and it stoped makin noise
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
01-08-2011, 12:56 AM | #7 |
Hmmmmm! I was told I was drinking that there isn't any vacuum on the choke. Mine was leaking and making a whistling noise. I made a temporay plug to end the leak and she ran better! I will have to have someone read this thread!
01-08-2011, 02:09 PM | #8 |
Very simple solution....Put a factory Q-jet on it
'72 chevy k20 '06 H-D Springer softail http://www.bluemooncruisers.com/ http://www.enginecycle.com/ ~Eric |
01-09-2011, 05:19 PM | #9 |
@72chevyk10- it does sound like air sucking. You mentioned it could be the secondarys, is there something i would need to adjust/clean to stop it from happening? I have a stock intake w/adapter for carb.
Posted via Mobile Device |
01-09-2011, 05:42 PM | #10 |
I built it
does the engine otherwise run good? (besides the noise) like no stumbles, bogs.. etc.? i personaly like the noise so ive never tried to stop it i dont know if there is a way to or not.. mine isnt a "screaming air" sound its more of a "compressed air" type sound
and does it quiet down at wide open?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs Last edited by 72chevyk10; 01-09-2011 at 05:51 PM. |
01-09-2011, 05:45 PM | #11 |
I built it
if it is the choke.. i didnt even know there was vacuum to it so it may be that too
