03-10-2003, 05:28 PM | #1 |
Longtime Member
E-brake
For some reason or another, the previous owner removed the e-brake pedal assembly and release. The cable is still there, just not the assembly. Do I need to find an original, or will one of the later models (73-up) fit?
Rokcrln - "I'm a major car addict so trying to go as low buck as possible is like asking a coke head to use flower to save money." 1972 C10 Short Step -http://67-72chevytrucks.com/vboard/s...d.php?t=261405 |
03-10-2003, 05:42 PM | #2 |
69-72 pedal only. pretty easy removal and install only 2 nuts.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-10-2003, 06:16 PM | #3 |
Almost Satisfied
I pulled mine out of my 71 and will not be using an e-brake. Let me know if you can't find the pedal assembly locally.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
