01-09-2011, 04:52 PM | #1 |
LSX addict
'82 6.0 swap HEDDER/MANIFOLD question
after much searching and confusion, i still have no idea who or where makes a LT hedder that will DEFINITELY fit my project. can someone please point me in the correct direction? also, i have F-body manifolds from an 01 SS i used to own. does anyone have confirmation that these will fit? if so i will just use them until a definite fitting hedder is released.
01-09-2011, 06:49 PM | #2 |
Re: '82 6.0 swap HEDDER/MANIFOLD question
I dont have a square but I am told that Doug Thorely has LT header for your truck with the LS, also I have been told the TBSS manifolds work weel where you need them tucked close to the motor like block hugger shortie headers.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-09-2011, 07:16 PM | #3 |
Dougs last time i checked does not have any. S&P sells some for close to 600 for shorties. I am going to try 98-02 f body headers. There is a person on here that has them installed. Think he had to slightly modify his controll arm or something.
http://67-72chevytrucks.com/vboard/s...d.php?t=411567
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
01-10-2011, 12:58 PM | #4 | |
LSX addict
01-10-2011, 01:55 PM | #5 |
I used Sanderson Headers on my swap, I like them but they are shorties and you might not want those, give them a call and see if they can help you.
01-11-2011, 11:07 AM | #6 |
These are the only ones I've found. They are made by Heddman and are a bit pricey but like I said, they are the only ones I've found.
http://www.brphotrods.com/mm5/mercha...ory_Code=CNV10
Stu- 1981 GMC Sierra Classic LWB 355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992 700R4-2000 stall with lockup, shift kit, Corvette servo 3.07 open diff- I need a 3.73 posi! 2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me. |
01-11-2011, 11:14 AM | #7 | |
LSX addict
Tags |
73-87, fbody manifolds, lq4 hedder, ls swap hedder, lsx hedder |
