which tank should i get?
I have a 72 blazer. I need a new tank anyways. I want something thinner than the factory tank. I see the 73+ blazer tanks fit with a little modification. I am unsure about a 25 gal or 31 gal. Is there a specific year that will be baffled and have an in-tank pump that will give the correct PSI?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
![]() Join Date: Aug 2004
Re: which tank should i get?
You would need to look at the 87 to 91 blazer tanks for EFI pump, but IDK if it would supply the 58PSI for the motor or if you would need to change the pump out.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Is there a pump that fits this tank and would give the proper PSI?
TBI pumps are made to run 9-13 psi. Tuned port injection requires the higher pressure you need. Sometimes a TPI pump can be made to fit in a TBI sender. Look at 85-92 camaro pumps. If you get into LT1 and LS1 applications they use a composite pump that is is a different design and less adaptable unless you want to do more modification to the tank.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
i see alot of people using the tbi fuel tanks with a corvette pump ran just like the tbi because they didn't want to use external pumps ill look for more info about it
anyone else?
I used a 87+ tbi 25gallon tank in my 71 Blazer with 4" spring lift. It sits just behind/above the differential. I moved the rearmost cross member back to the end of the frame rails. The aftermarket tanks have a "baffle"...but it is just a really shallow reservoir. The OEM tanks have the full baffling...unless I just bought the wrong brand.
The fuel pump is another story. You'll have to get an intank fuel pump rated for the LSx motor. It should fit in the stock position/tank. I THINK I used an ACDELCO EP381 with a corvette regulator/filter WIX 33737.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
