Old 01-11-2011, 04:22 AM   #1
Nukes16
Nukes16's Avatar
700r Tranny issue
Hey guys, I'm hoping one of you can help me out. I finally got my new winter baby (86 short-fleet) on the road but it is struggling to stay in 4th gear. When I'm cruising down the highway at about 60 and I've barely got any pressure on the pedal it keeps shifting down to 3rd instead of staying in 4th. It seems to happen on straight, level sections of the road.... when it should be just lugging along. It will go back up into 4th if I accelerate a bit first or chop the throttle completely. I've checked the tranny fluid and it is up to par. Any suggestions would be great!
Cheers
Nukes16 is offline   Reply With Quote
Old 01-11-2011, 09:02 AM   #2
BigBlocksRule
Re: 700r Tranny issue
Have you double checked the setting of the cable? Sounds like it's adjusted a bit short. Do a quick Google search, instructions for setting 'em are all over the net.
BigBlocksRule is offline   Reply With Quote
Old 01-11-2011, 12:05 PM   #3
Nukes16
Nukes16's Avatar
Thanks for the tip, I'll check it out. I'm not much of a transmission guy, but I'll try to figure out what that means.
Cheers
Old 01-11-2011, 01:08 PM   #4
BigBlocksRule
The 700 uses a different type of cable to control shifts. If it's incorrectly set, it will shift at the wrong time, can actually cause damage. They're not hard to set, just make sure you understand how to do it before you start.
Old 01-11-2011, 02:35 PM   #5
Malo83
Cruzzzn' Vet
Malo83's Avatar
Try this
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Malo83 is offline   Reply With Quote
