Old 01-11-2011, 06:13 PM   #1
K20-69-POS
Worth it?
I currently have a 14 bolt waiting to bolt into my project, but there is one for sale that is right around an hour away that seems pretty good for $700 the pros & cons of each are listed below, Should I buy this axle and sell mine for some idiot on ebay or should I stick with what I have?
Axle I have:
Pros:
-Spring pads are there and I should be able to bolt them in the '69 K20 (right?)
-I already have it (no traveling)
Cons;
-I plan on converting to disc brakes which will take time and money
-I have no way of proving this but may have been mis-treated (drum is cracked and shock mount broken off.
Other axle
Pros:
-Already converted to disc brakes. (saves time, and then I won't have to buy stuff to convert)
-has a truss welded on
(http://diy4x.com/cart/index.php?rout...product_id=151)
- New bearings/ seals (not actually "just put in" they were put in 2 years ago, but axle was never used)
-Rotors are usable
Cons:
-$700 (already am $900 into mil-spec dana 60 and 14 bolt rear, so I would need to sell the rear I have now for a decent amount)
-surface rust (equal to or less than the one I already have so really dosent matter)
-1 hour away
-Spring pads are gone, set up for coil springs, so would have to cut those off and weld on spring pads & shock mounts (I have to weld shock mounts on the axle I have now too)
*Again I would try sell the one I have if I purchased this one, I would try to get $500-600 out of it,
WHAT WOULD YOU GUYS DO IF YOU WERE IN MY SITUATION?
'69 K20 292 4spd 4x4 - project 27,000 orig. miles
'98 1500 suburban 4x4 - driver 219000 orig. miles
K20-69-POS is offline   Reply With Quote
Old 01-11-2011, 06:41 PM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: Worth it?
I don't know about your area but around here I can pick up 14 bolt rears for between 100 and 200 bucks..sometimes even cheaper! I would stick with what you have and just add the disc brakes yourself..its gonna be way cheaper than 700 bucks to do the job. You really dont know what either axle has been thru so put the money in the one you have and when its done you'll know what ya got!
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 01-11-2011, 06:50 PM   #3
72longbed
72longbed's Avatar
Re: Worth it?
I agree. The 14 bolt that you have will cost you much less to convert. You already have the spring perches in place - BIG PLUS!! - and you don't have to travel.
It isn't that difficult to convert your 14 bolt to disk brakes ... and it's cheap.
Just my opinion.
72longbed
72longbed is offline   Reply With Quote
Old 01-11-2011, 07:27 PM   #4
K20-69-POS
Re: Worth it?
Thats pretty good pricing, in my area i've seen them that low but they are for the none military axles (most of them are non locked and 4.10 and numerically lower gears). But if I could sell the axle I have for $500 and buy this axle for $700, then it would be like I only spent $200 and this axle has way more than $200 in parts, like the disc conversion and the truss. I am still on the fence with this one, but I need to make a decision in the next 3-5 days.
Old 01-11-2011, 11:55 PM   #5
K20-69-POS
Re: Worth it?
Alright you guys have convinced me, I guess I'll stick with the axle I have.
Old 01-12-2011, 12:49 AM   #6
scottsdaleowner75
Re: Worth it?
You guys are finding 14BFF for 100-200 bucks? Are you sure they arent semi floaters?
scottsdaleowner75 is offline   Reply With Quote
Old 01-13-2011, 03:09 AM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Worth it?
^ I just bought a 14 Bolt Full Floater for $100 - 15 mins from my house.
There's one about a 45 min drive from me for $75.
And another about 35 mins from me for 125 obo.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-13-2011, 02:03 PM   #8
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Re: Worth it?
you bring a nice rust free cab and front clip and I'll meet you half way with TWO 14 bolts! How's that for a deal?
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 01-13-2011, 03:03 PM   #9
Redcap
Re: Worth it?
Locally, they sell for between $30 for an open in useable condition and at absolute best $100 for one with a locker rear in nice shape.
Redcap is offline   Reply With Quote
Old 01-13-2011, 05:56 PM   #10
MTCK
MTCK's Avatar
Re: Worth it?
If the one you have now is mil-spec it is a 4.56 R&P with a detroit locker in it, correct? I'd put the brakes and whatever else it needs on it. $700 sounds way expensive, but whatever the market will bear I suppose....
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-15-2011, 11:58 PM   #11
K20-69-POS
Re: Worth it?
Yea its 4.56 and has the locker, I'm definitly just going to keep it and convert it, plus I would have had to move the shock mounts on it anyway so it doesnt matter that one is broken off.
I haven't been searching recently but I could only really find 14 bolts that came with front axles and the best I could find on craigslist in PA recently was $550 for mil-spec 14 bolt and dana 60, which I thought wasen't bad considering I spent $900 on my set.
Old 01-13-2011, 07:22 PM   #12
scottsdaleowner75
Re: Worth it?
HAHA you guys get all the nice 1 tone drivetrain stuff be we have all the clean rust free bodies. Classic. Yeah around here a CUCV 14bff with 4.56 and detroit will run you about $700-1000. If you want the matching open dana 60 another $400 at least. Here is an example and this is actually a GOOD DEAL: http://losangeles.craigslist.org/lgb...157709140.html
This guy is just freaking nuts!: http://losangeles.craigslist.org/lgb...147204072.html
