01-12-2011, 02:51 PM | #1 |
my 8 lug wheel to 5 lug
is it possible to find this 8 lug wheel in a 5 lug or not at all im ganna be taking the 8 lugs wheel off preatty soon i just wanted to know if anyone of any 5lug that look the same to the 8 lug
01-12-2011, 03:00 PM | #2 |
Who Me?
Re: my 8 lug wheel to 5 lug
Im sure there is. I have 6 lugs that look like that on.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
01-12-2011, 03:04 PM | #3 |
i hope cause if there is i dont know what im ganna do with them i have 2 or 3 extra spares really hope theres a 5 lug wheel i like this out there
01-12-2011, 03:06 PM | #4 |
Who Me?
Are you trying to convert your 8 lug to 5 lug?
01-12-2011, 03:15 PM | #5 |
yea im almost done rebuilding the front end i got from 75 chevy i just need to sand and powder coat them or i migth just rattle can them
01-12-2011, 05:59 PM | #6 |
Registered Loser
I am using a set of stock steelies from a 92 Chevy. They look pretty close but they have more lip. They are 5 x 5" bolt pattern.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. Last edited by creep; 01-12-2011 at 06:00 PM. |
01-12-2011, 06:06 PM | #7 |
is it possible to add a bigger tire to it?
01-13-2011, 10:45 AM | #8 |
Registered Loser
I don't see why you couldn't. The tire in the pic is about 29" tall.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
01-13-2011, 04:20 PM | #9 |
Senior Enthusiast
If you just want flat stock type wheels, you can always use 5 lug 1973 and up Chevy truck wheels. Here’s a shot of a 15x6, which will accept any standard 10 1/8” hubcap.
If you want to retain the clip style hubcaps I’m afraid you’ll be out of luck. The last of the clip style wheels were in the 6 lug pattern. 1949-53 Chevy passenger cars used 15” clip style wheels, but they are 4 ¾” bolt circle. Early 50’s Oldsmobiles (and I believe Pontiacs) had clip style wheels in 5x5” bolt pattern, but I don’t know if truck hubcaps will fit on them. |
01-13-2011, 04:34 PM | #10 |
not really worried about any hupcaps to be honest i just cant make my mind up im almost done rebuildin my suspension but i had to stop sence there isnt any work at the time rigth now but once i can get the suspension bolted infrm there im lost in what type of wheels i wanna go i like the chrome rims but also like the big mud tire i just dont know which direction to go.
01-15-2011, 09:33 PM | #11 |
What size are the 8 lug rims ?
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
01-16-2011, 12:19 AM | #12 |
I assume by suspension, you mean you're replacing that 3/4 ton axle in your first pic? I have never seen a 5 lug brake drum made for a 3/4 ton axle...
01-16-2011, 02:48 PM | #13 | ||
that a good question sence i was just looking into that one the other day i went to start up the engine for a lil bit also its was really hard to tell sence the tires are cracking now i'll have to go check today be 2-3 spare tires they should all be the same i'll have to look into it later today i'll try to take pic also. Quote:
01-16-2011, 11:56 PM | #14 |
wasnt able to get any pics but the size is 7.50x16 8lug all the way around
