Eat, Sleep, Drive a Chevy
New Autometer Phantom gauges
I have a new bezel with new autometer phantom gauges for sale. I am going another direction so I dont need these any more. The gauges are 2 1/16 in size. The gauges are electric except for the oil pressure which is mechanical. A 5 in Speedo and Tach will fit perfectly in the large holes.
175.00 shipped to lower 48
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
![]() Join Date: Jul 2009
Re: New Autometer Phantom gauges
where in texas are you located and what size is the medium hole
1972 SWB Medium Olive South Houston Instagram: Antbish84 Last edited by POPO1984; 01-12-2011 at 09:59 PM. |
Retired Air Force Veteran
![]() Join Date: Aug 2007
The medium hole as in the middle hole between the 2 large ones? If that's what your talking about, it's 3-1/2 inches
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
thanks for answering the question for me myoldchevytruck! as for the other one
I am in Ft Worth...aka "cowtown" therefore I call it "the town of the cow"...lol
No problem, good luck with the sale
Ok thanks ill pass
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
#7 | |
dave
i'm putting in a 6.0 2005 lq4 motor in my 72 burb so i need all electric guages will this work? and does it come with the bezel ? thx dave
check out my build "DIRTY BURB" ![]() |
Hi Dave
The oil pressure gauge is a mechanical gauge just like the factory one that came on your truck. It will need to be connected by a small tube to the engine to pick up oil pressure. Your engine will have a oil switch that you can tee into, or you could use a spare port on the block, usually near the oil filter. The volt gauge simply connects to a 12volt source, the fuel gauge is for a 0-90 ohm sender same as the factory tank has. The water temp gauge connects to the heat sending unit. You should have no problems with getting these hooked up to your 6 ltr. Yes the bezel is included with the gauges
I also still have the papers that came with the gauges
ttt
dave
i'll check my fitment when i'm home from work my tach is in the middle soooo need to figure it all out thx dave
dave
pm sent
replied to pm
