Awwww help im getting mad
ok as my title says im getting mad and thats when you start missing things ...
so here it is about 2 weeks ago i replaced all my plugs, wires, cap, and roter.... ran better then ever soo soo happy. then on New Years Eve a lady backed into my front passenger side in a parking lot =*( "yes i cried" No major damage slow speed fender bender. damaged front fender bumper brush guard marker lights and bezel. Engine compartment appears unaffected. Now runs very bad. Misses at idle gets worse with throttle often stalls like someone messed with plug wires (didn't happen). I have checked all plugs wires cap rotter. Got it all and making good connection. what should i check look at anything. I don't think it has to do anything with the crash but why did it run great then not? I need to get this running well again its my daily driver please and thank you |
Re: Awwww help im getting mad
check your vacuum lines. recheck your plug wires with a multi meter, maybe there is a bad connection.
sometimes a jar can knock a coil out. You might want to check the output of the coil.
JESUS IS LORD 87 crew cab V30 454/400 |
Check everything electrical. Make sure the dizzy is clamped down tight.
edited the post to get rid of the useless chatter... lets keep this on topic Last edited by old Rusty C10; 01-13-2011 at 12:20 PM. |
if it started running like crap after she hit you on the passanger side Id start with battery ground straps and other electrical on that side
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
GoatLube Experss
![]() Join Date: Oct 2009
I agree, I recently had similar trouble and it turn'd out to be a bad ground. sucks bout the hit !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
