01-14-2011, 02:52 AM | #1 |
Lowering question..wanna make sure.
I have a 71 c10 LWB. I wanna lower it down a bit. I'm thinking of using drop springs. The question I have is do I measure from the top of the tire to the top curve of the wheel well or do i measure from the top of the tire to the actual inside of the wheel well? I really don't wanna get into drop spindles just the coils..kinda on a budget. I don't wanna lay frame just want a little drop but that is drivable. Thanks
It's not rust...It's character! |
01-14-2011, 03:00 AM | #2 |
Re: Lowering question..wanna make sure.
Much more drop than two inches on a spring and you will have a pretty rough ride and you might run into alignment issues. The tire is about 4" from the apex of the wheel well on a stock set up, and there is acres of space inside the wheel well and you will not have to worry about any clearance with such a mild lowering.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
01-14-2011, 11:28 AM | #3 |
So will i measure from the top apex of the wheel opening to the top of the tire, to detremine how many inches i want to go down?
01-14-2011, 12:01 PM | #4 | |
The easiest view is the gap between the top of the tire & the wheel well lip. The variance here is different height tires yield different results w/the same drop (a 2" drop on these trucks w/a 25" tall tire will look different vs. a 2" drop w/27.5" tall tires) so it's something you have to keep in mind.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-14-2011 at 11:26 PM. |
01-14-2011, 12:16 PM | #5 |
Thanks guys...
01-14-2011, 03:31 PM | #6 |
Remember that tires are temporary, the fender and the ground reletionship are constant. Measure from the apex of the fender well to the ground to get a pre-lowering height, then determine what size spring you need and install it. Drive it up the block and back to settle the suspension then into the same spot you first measured it. Should be close to your estimation of drop. Then take it to the alignment shop.
01-14-2011, 10:13 PM | #7 |
67-72 parts collector,…
Remember a 2" drop spring is 2" lower than a new stock height spring.
(not your 40 year old springs, that are probably sagging) I doubt adding a 2" drop spring to your truck will yield a 2" drop. Probably more like a 1" drop compared to what you have now.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-14-2011 at 10:14 PM. |
