01-16-2011, 01:04 PM | #1 |
Future TOTM Winner
Crossover Steering, who has it and do you have any pics?
Beings my 72 K5 is torn apart I was thinking about going down the crossover steering path. I might one day lift it more than the current 6 inches so I figured better to do now than later. I would like to use as many "parts house" parts as possible for ease of replacment but if ordering a complete kit from someone like ORD is what I need to do then thats what I'll do.
My Blazer isn't going to be abused. It will probably be on the pavement the majority of its life after the rebuild is completed. It will go on some light trails, beach, hunting trips, etc but that's about it. I'm mainly thinking about doing this swap for the drivablilty with a lift. So if you have made the swap, especially on a 67-72 please share it or point me in the direction of another post. I have been reading on the "other" websites that are a little more off road oriented, but I would rather talk to you guys if possible.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
01-16-2011, 08:29 PM | #2 |
Grease Monkey
Re: Crossover Steering, who has it and do you have any pics?
Try doing a search. There are a few threads already started about this topic.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
01-16-2011, 09:18 PM | #3 |
Future TOTM Winner
I ran a search a week ago, I did another before I started this thread, and I did one more just now. I have yet to see a thread about crossover steering. I'm sure there is some info buried in peoples build threads here and there but of the ones I have checked I haven't run across anything. I'm know there is info somewhere that's why originally I asked to "point me in the direction of another post".
I'm sure some one will point out an obvious post and try to make me feel dumb for not seeing it earlier, but I'm fine with that, at least I will have some more info.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 01-16-2011 at 09:19 PM. |
01-16-2011, 09:31 PM | #4 |
i plan on doing it later on my suburban but what front end do you have, i don't see alot of people doing it but they are out there
01-16-2011, 09:52 PM | #5 |
Grease Monkey
Here are some threads I found.
http://67-72chevytrucks.com/vboard/s...sover+steering http://67-72chevytrucks.com/vboard/s...sover+steering Here is a list of parts you will need. 2wd chevy steering box, helm joints, DOM tubing, steering arm, and flat top knuckle (dana 44). I would also recommend using a trac bar. I take some pictures of my new setup tomorrow.
01-16-2011, 10:22 PM | #6 | |
Future TOTM Winner
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 01-16-2011 at 10:27 PM. |
01-17-2011, 11:15 AM | #7 |
I have crossover on my 72 K5. There are some posts with pics of my set-up on here. I will try to find them.
update: couldnt find my crossover pics, but here is some pitman arm info that you might need. http://67-72chevytrucks.com/vboard/s...d.php?t=290677
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania Last edited by OLDCHEV4X4; 01-17-2011 at 11:24 AM. |
01-16-2011, 10:20 PM | #8 |
Future TOTM Winner
The stock 6 lug dana 44 is sitting under it at the moment, but it is going to either get changed over to 8 lugs or the entire axle will be swapped out before it's driven again. It seems that the dana axles up to 76 already have a flat spot on the passenger knuckle, just have to have it drilled and tapped for studs. That brings up one of my questions, has anyone tried connecting the drag link to the opposite side of the tie rod instead of going all the way to the steering knuckle? I have seen quite a few stock trucks with this setup (my 2006 Dodge Cummins is one of them). Seems like finding parts might be easier but this link makes it sound like its not as ideal of a situation.
I'm talking about the second setup on this page. http://www.offroaders.com/tech/Steering-Systems.htm
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 01-16-2011 at 10:24 PM. |
01-17-2011, 02:32 PM | #9 |
If you decide to go with a Dana 60 I can give you some part #'s and pics
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
01-17-2011, 03:24 PM | #10 |
There is a guy who did a "how to" on it over at the "Colorado K5" site. I am doing it on my blazer. I plan on ordering my parts in the very near future. Just haven't made up my mind who to buy from.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
01-17-2011, 03:24 PM | #11 |
Future TOTM Winner
I'm all about swapping in a D60 but I am having trouble justifying the cost for this particular Blazer. I don't think I will abuse it enough to need one. It would make crossover steering a lot easier. I have been casually keeping my eyes open for one to fall in my lap (yeah, right!) so you never know.
On another note, how crucial is the panhard bar? I realize it will keep the lateral movement of the axle from pulling back on the steering, but for my purposes is it really necessarily? I see some people use it, some don't.
01-17-2011, 04:02 PM | #12 |
Crossover/Highsteer D60 w/Hydro Assist
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
