rearend swap questions
First time poster, long time learner.
I have the said '65 below. Some number of years ago, I swapped out the original rearend for a '70 c10 5lug with 3:08 non posi. A few years ago, found some great original ralley wheels. When I put them on, the wheels tires wouldn't fit under the rear fenders, there was about a half inch sticking out past the fenders on each side. Since attempting to put them on, I took the fenders off to figure out what the deal is, but to no avail. The only thing I can think of is there is a size difference between the years I didn't account for or know about. Ralley wheels I got are 15x8 with tires of 255/60. Something isn't adding up in my brain here. Heres the questions, are the rearends different sizes (backing plate to backing plate)? I was told there is a spacer or adapter that needs to be removed, but I don't see one, so where would it be? Finally, if the rearend I got came out of a '70 Suburban 1/2ton, is there difference there as well? Would appreciate any assistance. Bret
1965 Chevy short-step side, work in progress.... ............................____ ..................______l/___\____ .................|_/(0)\_ll____/(0)_l. |
![]() Join Date: Mar 2010
Width of the rears ends changed sometime after 70...+ 1.5 inches(I think)
Luc
65 burb On the road Mar 26th Finally |
Senior Car Nut
![]() Join Date: Jan 2008
Re: rearend swap questions
5 lugs didn't start until '71 but yes the rears got wider sometime in '70 by 3/4" each side, still shouldn't be enough to cause a problem. what is the back spacing on those 8" rallyes. I'm still running the PO's 8" rims with a backspacing of only 2 inches and the PO had to flatten the fender lip for clearance. normal backspacing is 3 1/4" I think which should give enough clearance.
Larry |
![]() Join Date: Feb 2010
You may have 4x4 rallys. I think they have a more centered type backspacing. Rims that have a deep look to them probably wont work. You need a set that has like 4 to 5 in of backspacing. Too much backspace and tires will hit the wheel tub towards the center of the truck. Do some measuring. Go to the junkyard and look for newer truck rims. They have more backspacing. Here is a picture of ones im looking for. Late 90's, 2000's rims. They look to have at least 4.5 of backspacing.
Guess I should have re-read my post before putting it up. The rearend is in fact out of a '71 not a '70. Thanks for the correction as well.
I'll check the back spacing on the wheels. The wheels are 5 on 5 I do know that for sure. At the same time as I measure back spacing, I'll get the backing plate to backing plate measurement. Is it a common theme having to roll the fender lip with any new(er) wheels? Edit: Wheel back spacing is 4 1/4". Backing plate to backing plate appears to be 56 3/4" (inside dimension of backing plates).
1965 Chevy short-step side, work in progress.... ............................____ ..................______l/___\____ .................|_/(0)\_ll____/(0)_l. Last edited by Bret B; 01-17-2011 at 04:19 PM. Reason: more information |
Done some more looking into this rearend. The rear end I have came from a '71 Suburban. From backing plate to backing plate my tape shows 56-3/4 inches. Wheel mate surface to mate surface (WMS) shows 64-3/8 inches.
Not sure if it's a date stamp inside the wheel, but it says 8 20 84. All said, I'm still at an impass with the decision, but at least I know more of what I'm up against.
Another option may be a custom offset from one of the replica wheel manufactures.
David |
