01-17-2011, 01:39 AM | #1 |
Got a airbag question????
Ok I've had this idea forever, I'd like to have a hydraulic or air ram at all 4 corners, preferrably air to lift in just and inch or so off of the ground to change tires, if im running air bags do you think the pump and tanks would support the jacks?
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet 1994 Buick Roadmaster 1994 GMC Sonoma |
01-17-2011, 02:25 AM | #2 |
Re: Got a airbag question????
that is a cool idea to have jacks
01-17-2011, 02:45 AM | #3 |
Also boxing the frame and using it as an air tank, possibly for the bags and jacks or maybe just one or the other and running a small tank for watever the frame doesnt feed
01-17-2011, 06:30 AM | #4 |
If I did that I'd try to make the car jump like speed would do in the mach 5
70 SWB STEPSIDE 70 BLAZER 09 challenger |
01-17-2011, 07:08 AM | #5 |
Stalker Nate
This is basically what you want to use/do to your truck. The exact same thing that motorhomes have. You could probably piece the system together buying seperate hydraulic jacks cheaper.
http://powerpluslevelers.com/Product...oductId=135466 |
