01-17-2011, 01:54 AM | #1 |
Need advice on the best way to build a reliable 2.8
The original 2.8 in my 87 blazer blew, well not totally blown but knockin really really bad and its not drivable in that condition, assuming its a good motor like the guy said i got a deal on another 2.8 for $50, I dont wanna drop it in and then 5,000 miles down the road be doin another engine swap so what is my best option for the new engine?
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet 1994 Buick Roadmaster 1994 GMC Sonoma |
01-17-2011, 09:39 AM | #2 |
Re: Need advice on the best way to build a reliable 2.8
Make sure you get an 87 or newer block - they have bigger main bearings. Or you could go for a 3.1L out of a Camaro. Also, keep in mind these motors have flat tappet cams and need the higher zinc oils.
How many miles do you have on your current 2.8?
69 Chevy C10 88 Sierra 02 2500 Suburban And too many S10s to list! |
01-17-2011, 07:00 PM | #3 |
272319 miles
01-17-2011, 10:36 PM | #4 |
BAD BOW-Silverado XST
Ouch! Time for new bearings! You can turn the crank for new bearings. Install new bearings on the rods and you can drive it until it is really toast.
01-26-2011, 04:26 PM | #5 |
Active Member
Will everything off the 2.8 bolt onto the 3.1. Also do they make any performance upgrades for the 2.8 or 3.1 such as alum. heads, cams, valve springs,etc. Ive always wanted a 200-300 horespower 2.8 dont know if its possible. If it is let me know
01-28-2011, 01:39 AM | #6 |
X2 I'm with michaelnolimit on that question, I'd love a powerful and still very reliable 2.8 or even a 3.1
01-30-2011, 11:26 PM | #7 |
when you put a 3.1 in place of a 2.8 you need to swap intakes, then its a direct bolt in. a 3.1 is basically a stroked 2.8. there are some performance parts out there for these little motors but they are limited. I've seen over at s10forums a supercharged 2.8.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
01-30-2011, 11:28 PM | #8 |
gets board easy.......
3.1 is the only way to go.
any front wheel drive 3.1 will work |
02-01-2011, 09:30 AM | #9 |
OR, you could swap in a 3.4L from a Camaro/Firebird and then run a 4.3L throttle body.
02-01-2011, 10:31 AM | #10 |
Always trouble
Thats what I plan on doing. I got a 3.4 out of my friends 95 camero. I am planning on re-building it with a few goodies and then dropping it in. And on the throttle body, you dont have to run a 4.3 throttle body, you just need the injectors off of one.
91 Silverado Regular cab, 2wd, swb-project truck 97 Silverado Extended cab, 2wd, swb-driver |
02-01-2011, 06:18 PM | #11 | |
There is alot of info on these swaps over at s10forum.com. But be for warned. guys over there aren't as nice and respectable as the guys over here.
02-01-2011, 11:12 PM | #12 |
Always trouble
I know its better to run a 4.3 throttle body, I was just stating you dont have to. And your right about the S10forum, a lot different then this forum.
02-05-2011, 02:36 AM | #13 |
Great info guys, will any late model V6 bolt up to the stock trans?
