Old 03-11-2003, 09:25 PM   #1
da-burb
"Ochre Ogre"
da-burb's Avatar
Need info on front leaf springs 72 4x4 K20
Does anybody have the specs on front leaf springs handy? Maybe a part number you may have ordered. I found one of my springs broken at the front eye, left side. I am not looking for any additional lift at this time.
I would like the dimensions to make sure I am getting the correct set. eye to eye, width, weight capacity for a normal replacement spring. And if I have to find something used, what years are interchangable, 69-72 or 71-72?
I need to order them in the morning so any help is appreciated!
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 03-11-2003, 09:47 PM   #2
dat
According to my Hollander manual, the 64-66, 67, 68, 69-71, 72 and 73-76 are all different.
67 is 22 x 26 x 1 1/8" (encased rubber bushings and all two leaf but 3 different weights)
68 is 22 x 26 x 1 1/8" (different rubber bushings but 2 or 3 leaf)
69-71 is 22 x 22 x 1 1/8" (same bushings as '68 and 2 or 3 leaf)
For '72 it's 22 x 22 x 1 1/8" (2 or 3 leaf)
The wierd part is that it shows the dimensions ecactly the same but it also says they do NOT interchange. Have no idea why. It only lists '72 jimmy, '72 chev and GMC conv. cab trucks as interchange.
then '73 up is 23 1/2 x 23 1/2 x 1 1/8"
'68 GMC 1500 LWB Fleetside w/350 & 3 spd (for now)
dat is offline   Reply With Quote
Old 09-01-2024, 09:27 AM   #3
Oldswrench
Re: Need info on front leaf springs 72 4x4 K20
The wierd part is that it shows the dimensions ecactly the same but it also says they do NOT interchange. Have no idea why. It only lists '72 jimmy, '72 chev and GMC conv. cab trucks as interchange. Oh I guess this is pretty old, sorry.
I have a 67 4X4 frame and the front springs on it are 44" just like the 69 to 72. I don't think the Hollander manual is right! I want to use the 73 and up 47" springs instead of the B52 swap but I dont know what width they are.
Oldswrench is offline   Reply With Quote
Old 03-11-2003, 10:49 PM   #4
kwmech
I've always been able to swap the springs from 68 to 72 The only difference I have seen is 2 or 3 leaf but even traded and swapped because of exactly what you are up against.
Old 09-01-2024, 02:09 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
I can’t say for sure for the fronts but I know for sure the rears are a different width on 67-68 k-trucks. The front lengths are the same all thru the 67-72 years.
Tyler
57taskforce is online now   Reply With Quote
Old 09-04-2024, 02:09 PM   #6
MJN
MJN's Avatar
Here is what Husky Spring offers for front springs
https://huskyspring.com/Home/SearchResultGrid
2.5" wide, 44" overall (22x22), 2 or 3 leaf, 1" thick for 2 leaf pack, 1 5/16" thick for 3 leaf pack
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
