Old 03-11-2003, 09:56 PM   #1
1972chevy4x4
1972chevy4x4's Avatar
5 bolt leaf spring rear info
Hello,
I am building a 1968 GMC short-step at this time and the truck has a six bolt leaf rear. I am converting to five bolt leaf rear and having trouble locating one. I know an original five bolt leaf is hard to come by so I was told I can convert a newer 73-87 rear to fit, but what is required? Looking to put a set of 3.73 in it. Any info will be helpful. P.S. how much wider is the newer rears than our older ones. Thanks Dan
1972 chevy k10 4x4 longbed 4-inch lift, 3.73 front/rears, frame off nearly complete
1972 chevy k10 4x4 longbed parts truck, known as the "ugly green machine"
1990 GMC 3/4 shortbed ext cab
Always in need of 67-72 parts in central ks.
1972chevy4x4 is offline   Reply With Quote
Old 03-11-2003, 10:38 PM   #2
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
70-72 rears are 1.5 inches wider than 67-69, thats all I know, dunno about the conversion, I have a 71 C-10 leaf truck and I got a posi rear sitting in the sher for it too
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 03-11-2003, 11:35 PM   #3
1972chevy4x4
If only I had a leaf spring posi sitting in my shed, all my problems could be solved. thanks for the post.
Old 03-12-2003, 12:31 AM   #4
67cst
i love summertime
67cst's Avatar
1972chevy4x4---->too bad you wernt closer, i have a 5 bolt leaf rear out of an 85 ... im sure if you got 73-87 you wont have problems finding something
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 03-12-2003, 11:23 AM   #5
1972chevy4x4
ttt
Old 03-12-2003, 03:47 PM   #6
Yellow Cheyenne
Check with board member gregsplace-in the past he has had what you are looking for and he lives about 15 minutes from Wichita.
Randy
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 03-12-2003, 04:21 PM   #7
matt67350
matt67350's Avatar
Classic Truck Mag had a artical on this for a coil spring rearend
but they did touch on the leaf spring rearend.
Find a 12bolt with the gears you want and then have the saddle plates changed the fit the 68. Try Early Classic.com
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 03-12-2003, 05:30 PM   #8
Yellow Cheyenne
Board member Teeitup near Topeka had posi 3.73 for sale out of a 4x4 for $300 about a week ago.
'70 Olds Rallye 350
