01-18-2011, 12:25 AM | #1 |
drop shackles
i am trying to figure out what drop i got in back but dont know how much these drop shackles actually are also only got 2 leafs the main one and the last one dont know if they got different sizes in drop shackles
01-18-2011, 01:16 AM | #2 |
Re: drop shackles
2 in
01-18-2011, 12:34 PM | #3 |
Happy to be here
Re: drop shackles
Those can be set for 1" or 2" by using the upper or lower hole. Currently they are at 2".
01-18-2011, 09:37 PM | #4 |
Re: drop shackles
thanks alot you guys also what can i do to get either 5 or 6 inch drop with these shackles
01-18-2011, 09:39 PM | #5 |
Happy to be here
Re: drop shackles
Do a hanger kit, or raise your hanger for a total of 4" drop. If you want more go with a flip kit.
01-18-2011, 09:50 PM | #6 |
Re: drop shackles
how much does a hanger kit drop
01-18-2011, 10:05 PM | #7 | |
It Is What It Is,,,,
Re: drop shackles
After dropping mine,, To get those hangers off, I would of went with the flip!!! Ended up on doing both. After flipping really no need for the hangers. I moved em in close to the standard location. I would just do the flip, Much easier and it will drop you. But you WILL be looking into a C-Notch kit.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
01-18-2011, 10:08 PM | #8 |
Re: drop shackles
that is the thing im trying to get away from the c-notch is there any way i can do the 6 inch rear drop and staying away from the c notch
01-18-2011, 09:57 PM | #9 |
Happy to be here
Re: drop shackles
Hangers are 2" and shackle is 2" for a total of 4". You are going to need to do something with the spring pack though.
01-18-2011, 10:01 PM | #10 |
Re: drop shackles
ok thanks alot bro do you recommend drop shocks or shock extenders and which drop shocks also where the best place to buy drop kits from
01-18-2011, 10:49 PM | #11 |
Happy to be here
Re: drop shackles
With only 2 leafs in your spring pack, I think you will need a notch with 4" of drop.
01-18-2011, 11:46 PM | #12 |
Re: drop shackles
do ya think that if i replace my leafs i can do my flip kit with drop shackles and get my 6 drop and stay away from notch
01-28-2011, 06:55 PM | #13 |
Re: drop shackles
Also want to drop the rear of my truck 2". Do you guys recommend the shackles or the hangers? If I use the shackles, which are less than half the cost, is cutting the bed cross rail a must? Measuring with a tape, right now I have 2 1/2" between the rail and the leaf spring. Of course this is without any weight in the bed.
01-29-2011, 05:15 PM | #14 |
Re: drop shackles
Shouldn't matter.
The shackle, hanger, frame and bed all move together (vertically) as you add weight. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-29-2011, 07:35 PM | #15 |
Re: drop shackles
If you just do a flip kit you dont have to notch the frame, correct? I do believe you have to notch the frame if you go 6in or more with just a flip kit. I think their are a few people on here who said they did 6in total with a flip kit without a notch but wouldnt recomend carring any weight.
01-28-2011, 09:48 PM | #16 |
Happy to be here
Re: drop shackles
If your only going 2" then the shackle is the way to go. The length of your springs and bed will determine if you have to notch the bed channel.
01-28-2011, 11:54 PM | #17 |
Re: drop shackles
drop shackles cutting bed it may be a must but not hard at all just mark where shackles going to hit take bed off flip up is easier and just cut i left about a 1/4 inch so it still had strength in bed rail
