70Custom10
What engine am I working with here!?
Im having a hell of a time finding figuring out what exactly im working with here. Ive checked all over the forums and i keep ending up at broken links and expired websites. The number on the back side of the block is 3970010 so Ive gathered its a 350, as it should be. I was told this motor is a 350 bored .040 over out of a 72 C10. The motor is stripped down and sitting on an engine stand right now so if theres any other numbers i need to find that would help identify let me know.
I see 3 different numbers there 1st) V0830TBM 2ND) 7398 3RD)C97106606 |
Re: What engine am I working with here!?
i did a quick search in google and found this.
http://www.thedirtforum.com/castings.htm 3970010 68 - 79 350 & 327 145-375 2&4-Bolt mains/Truck/Hi Perf
84 Scottsdale LWB K10 Rooting against the cowboys is almost as fun as rooting for the GIANTS! Last edited by pseudopimp; 01-18-2011 at 02:28 PM. |
yep thats what i came up with also.
425hp409
![]() Join Date: Oct 2008
A good source for the information you are looking for is www.nastyz28.com
He shows that you have a 350 block, built in Flint, August 30, for a 69-79 car, truck or vette with either 2 or 4 bolt mains.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
TOTY 2006
![]() Join Date: Dec 1999
V=Flint
08=August 30= 30th day of month TBM was used for three different engines/years. 1. year=1970 Size=307 1/2 ton trucks 2. year=1979 Size=350 3/4 to 1 ton trucks 3. year=1985 Size=305 1/2 to 3/4 ton trucks. However, your block number indicates 1969-79 3970010 350, So with those two codes, you have a 1979 350 block. Kinda iffy, but the only other thing you could refer to is the heads, and what they are, but chances are they could have been swapped at one point. The other numbers on the engine pad, no clue other then maybe put there as part of a warranty exchange or record number by a machine shop? Last edited by John Fabris; 01-18-2011 at 05:23 PM. |
#6 | |
70Custom10
Tags |
350, block, eidentification, engine, vin |
