01-20-2011, 02:00 PM | #1 |
Cab Bushing Differences 1/2 to 3/4
Tried searching around and couldn't come up with a 100% positive answer..
Ordered a Cab Bushing kit.. got it.. but noticed that the kit states for a 67-72 3/4 or 1ton.. and I am replacing the bushings on 1/2 ton lwb (71) Are there any differences? Everything appears to be correct. Thanks in advance!
* 1968 GMC Swb - 98% done (current restoration) * 1971 Chevy Lwb - Retired Dump Hauler * 1982 K10 Longbox - New Dump Hauler Last edited by Deaol; 01-20-2011 at 02:01 PM. |
01-20-2011, 02:12 PM | #2 |
member #16
Re: Cab Bushing Differences 1/2 to 3/4
The rear cab mounts are different on a 3/4, one ton and 4x4. They are longer.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 01-20-2011 at 02:13 PM. |
01-20-2011, 11:03 PM | #3 |
its all about the +6 inches
2 wheel drive 1/2 ton takes one style, everything else takes the other style
01-20-2011, 11:25 PM | #4 |
Grandpa in the rustmobile...
Will replacing the old ones make it ride/handle/sound better lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-20-2011, 11:28 PM | #5 |
yes how will it feel ?
01-20-2011, 11:32 PM | #6 |
Hopefully alot better, this is an upgrade im going to do soon
01-20-2011, 11:35 PM | #7 |
as well as me to ! i still have my original 3/4 ton cab mounts holdin the cap up! they are doing a great job but i need the 1/2 ton mounts
01-20-2011, 11:53 PM | #8 |
Another ?
Should I go poly or rubber. I went with poly trailing arm bushings and they squeked forever. Which rides better? Thanks
01-21-2011, 07:39 AM | #9 |
Watch out for your cornhole !
Rubber rides better of course and won't make the noise of urethane but some guys like the urethane for it's longer life.
I change the cab mounts on every truck I buy since it stops so many squeaks, rattles, and allows all of the body parts to align with each other like the factory intended.
