Old 01-20-2011, 05:13 PM   #1
glider_6969
Question Power steering pump mounting
Hey Guys, need some help again.
I am going to upgrade the manual steering to power. I have the pump and the gear box, but wondering if anyone hear has any pictures of the pump mounted. The motor is a 350, and my alternator is on the right side of motor. I need to see what brackets are needed to mount it to the motor, this is what I have, I think I am missing one that goes mounted from the motor or head to the smaller bracket on the right of the pump in the picture. I'm sure there are pictures here, but I can't seem to find some that show what I am looking for. Thank again.
glider_6969 is offline   Reply With Quote
Old 01-20-2011, 05:42 PM   #2
john
member #16
john's Avatar
Re: Power steering pump mounting
I dont have a pic, but you are missing an "L" shaped bracket from end exhaust manifold bolt to the adj. bracket shown to fasten to.
john is offline   Reply With Quote
Old 01-20-2011, 08:27 PM   #3
JimKshortstep4x4
Here is a picture. As John mentioned you are missing the bracket that the adjuster bolts to.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-21-2011, 11:32 AM   #4
glider_6969
Jim
Hey Jim,
that's exactly what I was looking for, I knew I could count on you guys. It should be easy enough to find. I just may have to add a spacer, since I have headers on it .
Thanks again,,
Old 01-20-2011, 10:21 PM   #5
kev2809
low n' slo
kev2809's Avatar
maybe you can use one like this?
it came off my 305 with ram horns but it wont fit my other 305 (i have different manifolds on that one). i had it powdercoated last year but never used it.
btw, i have those same exact brackets and pulley you posted in the first pic
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
