Old 01-22-2011, 12:20 PM   #1
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
Question LWB 2wd truck with factory buddy seats & factory OVERDRIVE?
Buddy of mine just recently picked up a 68 (I think) LWB fleetside with SPID that lists bucket seats, but has buddy seats (would buddy seats be listed as bucket seats?) and SPID also says overdrive tranny. Did GM ever offer overdrive tranny on these trucks factory stock? There's a lever under the dash about in-line with the ammeter that looks like a black plastic pull lever that says "overdrive".
Forgot to add: it has 3 on the tree and v8, not sure if it's 350 or 327
Jason
Cap'n Hook is offline   Reply With Quote
Old 01-22-2011, 12:27 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: LWB 2wd truck with factory buddy seats & factory OVERDRIVE?
There was an OD 3 spd manual, I think its kinda sought after. Does the vin start out CE?
John
1999 Toyota Tacoma 4x4
Old 01-22-2011, 12:35 PM   #3
toms68cst
toms68cst's Avatar
Buddy seats are what we call around here bucket seats with the fold down center seat. It's just a term we coined around here. They were the 67-68 style offered.
I don't think the engine would be a 327 as I don't think they matched it up to the factory overdrive. It would have to be a 307. The factory OD is pretty unusual on our trucks. Not super desireable but adds to the cool factor.
Any pictures on hand to post???
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 01-22-2011, 01:54 PM   #4
CircusWagonJim
CircusWagonJim's Avatar
Since the 70's all the truck guys I know have always called them CST seats- was surprised to see all this talk about "Buddy Buckets". I don't get it- or do I want to sit next to my "buddy"- LOL!
CircusWagonJim is offline   Reply With Quote
Old 01-22-2011, 04:03 PM   #5
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
No pics, but it looks just like the white one in your avatar picture, white with the black hub caps, and blue interior!
So, it's probably a 307 and 4.11 gears then? It has the oil filler tube in the front center of the intake manifold.
Jason
Old 01-22-2011, 01:00 PM   #6
oldblue1968chevy
so 3rd is the od?
John
Old 01-22-2011, 01:02 PM   #7
tkeduk8r
tkeduk8r's Avatar
My uncle has an OD in his 69 (bought new) CST and according to him you couldnt get it on a 350 that year.... neat option IMO...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 01-22-2011, 01:06 PM   #8
too much stuff
Roadtrip!
too much stuff's Avatar
Here is mine with the bucket seats and overdrive. The seats aren't listed since they were standard on a CST in 67. The overdrive wasn't available behind any performance engine. Mine was a 283 truck.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-22-2011, 01:11 PM   #9
54blackhornet
54blackhornet's Avatar
Overdrive option in 67 was M10 Coat $118.40 Not Available with 327 V8 Not available in 68 with 327 or 396, came with 411 rear gear.....hope that helps
54blackhornet is offline   Reply With Quote
Old 01-22-2011, 09:16 PM   #10
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by oldblue1968chevy View Post
so 3rd is the od?
No, there is an auxillary unit that bolts to the back of the three speed trans that adds the O.D.
WIDESIDE72 is offline   Reply With Quote
Old 01-23-2011, 12:28 AM   #11
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
So then basically it's a 6 speed, with the 3 normal forward gears, and then the 3 gears after each normal forward gear when overdrive is engaged, since this is a manual 3 speed we're talking about, right?
Basically no different than a split rear end in 2 ton trucks as far as gearing is concerned?
Jason
Old 01-23-2011, 12:34 AM   #12
too much stuff
Roadtrip!
I believe it is only one shift after your final 1:1. You don't manually shift it in. I am going off a 67 ford i used to drive around that had it and you had to be doing 32 mph, foot off the gas, and than it would shift. Not sure if you hit 32 mph in first or second if it would shift or not... Not exactly sure how the GM one works...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 01-23-2011, 12:34 AM   #13
Nova70
Nova70's Avatar
More like a 4 speed.
'70 K10-- 4" lift on 35"s-- For Sale
http://www.ksl.com/index.php?sid=733...iew&ad=4578305
Nova70 is offline   Reply With Quote
Old 01-23-2011, 12:43 AM   #14
78bronzechariot
78bronzechariot's Avatar
I haven't ever driven on in a 60s truck, but I have driven a late 30s car with one. If they are like the older ones, they are centrifugally engaged. You pull the handle to "turn on" the overdrive then, you accelerate through first, second, and third then lift off the gas. Then the overrunning clutch disengages and allows the flyweights to engage a drum and engage overdrive. They usually won't have enough speed for the flyweights to engage until you are at 3rd gear road speeds. A cool side note is that with the overrunning clutch you can shift through second and third without the clutch before the o.d. engages. In the late thirties, an electric solenoid was added to allow a forced downshift out of overdrive. Before that, you had to downshift into "second-over" for passing and climbing steep grades, or slow down to the point where the flyweights would disengage.
78bronzechariot is offline   Reply With Quote
Old 01-22-2011, 09:50 PM   #15
oldblue1968chevy
Hmm, what kinda mileage would one pull with the factory OD?
John
Old 01-22-2011, 10:13 PM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
probably 10 to 12 like the average truck.
The stock overdrive was more to make up for low gearing.
A lame engine can feel stronger with deep gears (4.11 with a small diameter tire like the typical 1/2 ton) but then it is screaming at road speed, so add another gear on the top end. I'd bet a kick in the daddy parts that the cruise RPM would be somewhere around the same as the same engine with a 3 speed (or 4 speed, doesn't matter) and a 3.07 gear.
It was kind of the same idea as the granny gear 4 speed. 4 speed trucks (other than 307 small block ones) generally had the 3.07 gear (talking 1/2 ton here) It was driven like a 3 speed, but if you needed to pull on something, you'd actually use first. But then in final gear on the freeway, you were doing OK on the RPMs in the 2500 to 2700 area.
