Old 01-24-2011, 06:13 PM   #1
hamllik
hamllik's Avatar
66 K20 power steering
Hi I was wondering if anyone has done a power steering conversion on a 4x4 truck. I have seen one done on here for a 2 wheel drive. I think the box mounts the same I just need the info on the drag link for the steering. I have a 90 gmc 4x4 suburban that I can steal parts from so any info will be great.
hamllik is offline   Reply With Quote
Old 01-24-2011, 06:55 PM   #2
padresag
Re: 66 K20 power steering
box mounts similar, but the pitman arm travels in a different direction. get one of captfab mounting brkts here on the board
http://www.67-72chevytrucks.com/vboa...d.php?t=332923
ron
padresag is offline   Reply With Quote
Old 01-24-2011, 09:24 PM   #3
duallyjams
duallyjams's Avatar
Can you post a pic of yours.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-24-2011, 09:53 PM   #4
padresag
I don't know who you were asking but here is mine. I did make my own plate
ron
By rondavid at 2011-01-24
Old 01-25-2011, 02:29 AM   #5
Captainfab
60-66 Nut
I've sold several of my steerong box adapter plates to guys installing power steering on 4wd's. Are you keeping the '66 front differential, or switching to the '90 differential?
Old 01-25-2011, 09:33 PM   #6
hamllik
hamllik's Avatar
Yes I am keeping my original 66 front end. I figured the steering box would mount the same my question is can I use the newer burban drag link since the original is clocked different and not adjustable. I saw some where that some one had done this swap and told what year steering parts would work for a direct swap in. Like part of the drag link was s10 and the rest was k10 but I can't find the info again. I guess my question is more about the drag link. Any help is great and so far everyone has been real helpfull. Thank You
Old 01-26-2011, 01:39 AM   #7
Captainfab
60-66 Nut
I have a '69 K20 running gear that has power steering and a closed knuckle front diff. I'm thinking that the steering arm on the knuckle should be the same as on your '66. I don't have a pic of that right now. I'll try and get one tomorrow when I'm at the shop.
Old 01-26-2011, 01:41 PM   #8
padresag
By rondavid at 2011-01-26
here is the steering arm for the later str box
Old 02-17-2011, 03:14 AM   #9
clewin73
I have a 62 K10 I'm looking to do the same thing with. If anyone knows of an off the shelf steering link (or other solution) that works - that'd sure make it easier. I was figuring I'd have to fabricate one, or at least modify the current one to rotate the fitting 90 degrees.
clewin73 is offline   Reply With Quote
