The painting of hubcaps
So, as I get my wheels all sorted out here this spring, it comes time to deal with my rather rough looking hubcaps.
I have the four original hubcaps that my truck came with. They are chromed and should look like the top two. As you can see the other 2 don't. The chrome is still nice on all four, and since I need to refinish half of them, I figure I might as well do all four. How do I go about doing this? I don't have a lot of painting experience. I figure I can tape off and mask and then rattle can, but I don't anticipate that holding up very well. I have seen alot of really nice looking original hubcaps on here, some painted and some chromed. I figure at least a few of you have had to do this. Thanks for the input.
1969 C-20 Longhorn All original - 34xxx miles Planning a full frame off starting later in 2010 and through early 2011, and beyond... |
![]() Join Date: Aug 2010
Re: The painting of hubcaps
You asked, so here goes. I restored a set of similar caps a few years ago, and went all-out for a FACTORY look. They came out spot-on perfect, but it was a bunch of work.
1st, start with straight set of hubcaps and polish them up good. 2nd, take molds off a good cap using body filler and mold release. 3rd, shape your molded "plugs" to exactly fit what you DO NOT want to paint. Saw, sand, file, or do whatever works for you to get just the right fit. Plan your painting in stages, and create plugs for each stage or color. 4th, clean the metal well and paint away with good quality paint. Rattle cans are fine provided it's good paint and the tip atomizes well. You can soak the can in hot water to warm the paint and increase pressure if needed. A heat gun works too, but don't over do it. Next, enjoy hubcaps that don't have hard or crooked tape lines and display just the right amount of factory paint "bounce" on the edges. like I said, it's a bunch of work.. so you decide how you want it to look. Last edited by oem4me; 01-25-2011 at 11:29 PM. |
#3 | |
The Niner
![]() Join Date: Nov 2010
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
i'd tape off what you want to b chrome then steel wool to remove old paint and prep for painting/ remove the tape/wipe down with wax&grease remover then retape and paint with quality rattle can paint remove tape polish chrome and call it good to go
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 01-26-2011 at 08:42 AM. |
#5 | |
does this make sense? Last edited by oem4me; 01-26-2011 at 12:55 PM. |
I polished, cleaned the caps, then used painters vinyl tape (not wide, about 1/4, or 1/2 wide) to mask off the edges (vinyl tape is the the easiest to mask, it's flexible, and you get a clean edge), then roughen the area to paint with a course pad (3M pad), clean the area to be painted, then masked off the rest of the caps/area that I did not want to paint.
I painted the black first, let that set. Then, painted the red second. I used paint thinner around the edges of the red - a cloth, finger tip to remove any over spray (best to do this when the red is still wet). Obviously you're going with a different color, but you get the picture. I spent a lot of time prepping, masking to get good, clean lines. I also used good paint with a good tip (rattle can). I have a local automotive shop that will mix good paint in a can, with a good tip. I had an NOS cap to use as a reference and to also match paint colors. So - if you want to rattle can - that's what I did. Here are the pics of how they came out.
Doug '72 GMC K2500 Suburban 4x4 |
Thanks guys. I asked at the local NAPA and Advance and they can both match in their spray cans. As for the tape, all I can find is Frog Tape which is like blue painters tape but green and has something that leaves cleaner lines. Where do I find this vinyl tape and what does it look like? (I am picturing electrical tape and I know that's not right.)
Also should the black on these be flat and the blue gloss, cause thats what it looks like?
#8 | |
#9 | |
Google: "1/4"x36 Yd Plastic Tape" (scotch makes it). You can buy it online... this is the tape you want - it's much easier to work with on masking off the lines for the black part. -doug
i'd ask at NAPA or if you have an autopaint supply store//should b abli to find 1/4 or even1/8 tape at either place// the custom painters i know dont use plastic tape for thier graphics or flame jobs
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 01-28-2011 at 01:35 PM. |
I'll put up a few pics of what I was talking about in my earlier post. Doing it this way IS a fair amount of work, but I'm a kind of nut for details like soft edges and just slightly off-registered factory production work. ....plus, I can do a million more with little effort.
Each mold covers what you don't want to paint. |
oem4me, beautiful - nice work! How soon will the kits be available? hahahahahahh.... no, seriously....
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
The Niner
Very nice!
I just took mine to the sign painter today.
think the tape u are talking about is called fine line tape
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#15 |
Great looking caps oem4me!
#16 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'd consider powdercoat instead of paint for durability.
#17 |
Not to hijack, but I keep hearing about powdercoating and 2 things come to my mind since I'm not all that familiar with it
1) Since these caps "pop" on to secure themselves to the rims, won't the powdercoating chip off when you need to pop the caps on and off to remove wheels?? 2) Even if you p.c., won't you still have to paint the details to make it look stock ie, colored bowtie, and black cog appearance?? |
#18 |
Powder is quite tolerant of flexing so I can't forsee any issues in using it on hubcaps. I wouldn't use any paint at all on the hubcaps for details. I'd use the powder in place of the paint. It's no problem to do detail work with powders just like paint. Mask, shoot powder, touch up the edges if needed, then bake. Repeat as needed for different colors
#19 | |
I mean, mine is no show truck, and never will be. If it's three times as much that'd be a deal breaker for me. I appreciate your responses...I'm learnin! |
#20 |
I'd say three times the price for sure. Masking tape and paint is very inexpensive. Nothing wrong with that either. I just powdercoat my stuff because I can and I like the challenge of doing intricate stuff with it.
Lately I've been working with a buddy who does vinyl sign work. We're using his skills at that to make masks for powdercoating. Coat the base color, apply vinyl decal mask, apply second color and partial bake, remove mask, and full bake. Finally, a coat of clear powder over the whole deal to seal the edges down tight. We did this sprocket for his minibike that way. ![]() ![]() Previously I have always used high temp powdercoat masking tape for this stuff and it's tedious at best. We're still working out the bugs in the process but we're getting good results and it's much quicker and easier.
