Old 03-13-2003, 11:43 AM   #1
Bhull2
Question Filling in trim holes
What have you guys seen/done to fill in the trim holes along the fenders/cab/bed. Fiberglass/filler, lead, solder. welding.... Just wondering what has been done to fill these, and what all of my options are. thanks!
Bhull2 is offline   Reply With Quote
Old 03-13-2003, 11:47 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
I've never done it, but some of the guys on here recommend holding a copper penny on the back side of the hole and welding it shut.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 03-13-2003, 12:54 PM   #3
grebus1
grebus1's Avatar
Smile
I had all of trim holes mig welded on my Suburban when it was in the body shop for body work and paint. They welded up each hole, ground it down smooth, and then proceeded with the paint prep. I then used an adhesive type trim that I got from Cheyenne Pickup Parts (the kind used on the newer GM trucks) where the lower trim used to be. There is nothing where the upper trim used to be, just a color break. I think it looks great.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 03-13-2003, 01:54 PM   #4
smokekiki
Mike
smokekiki's Avatar
Have to be carefull with a copper penny.American pennies are plated.It can be welded to the back.You can use other copper or brass.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 03-13-2003, 01:59 PM   #5
70 longbed
Had mine welded and ground down, getting ready for paint soon; I hope.
70 longbed is offline   Reply With Quote
Old 03-13-2003, 02:00 PM   #6
Project1970
14.1 @ 96MPH
Project1970's Avatar
My dad had the upper trim line holes welded in in '89...there's bits of wire sticking out from the few spots I've been able to see the back of. The other side looks just fine.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 03-13-2003, 05:35 PM   #7
Bhull2
Thanks for all of the replies! Looks like I get to break out hte MIG this weekend!
