Old 01-28-2011, 01:52 PM   #1
RoyL
RoyL's Avatar
64-66 Chevy Stock Gauges - Voltmeter vs Ammeter (Batt)?
Anybody put a voltmeter in the stock guage cluster? Maybe in the big hole on the left side (where I'm told the "air' guage was for some bigger trucks)?
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 01-28-2011, 02:26 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: 64-66 Chevy Stock Gauges - Voltmeter vs Ammeter (Batt)?
I have not, first of all......but, I think it would be possible if you find one with a roughly 90* sweep. Most gauges have wider sweeps; I was considering a tach in dash and this is what I ran into. The re-pop vintage tachs have the short sweep but are too expensive for me to hack up to fit in a dash.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-29-2011, 07:21 AM   #3
RoyL
RoyL's Avatar
Good point on the small 90 sweep. I was thinking if I could find one really small, it might fit where the ammeter is . . . 2 in is the smallest I've seen. Don't want to cut on the original dash, but looks like the tach install required some cutting. I haven't taken one apart before, so not sure what's there.
Or leave it alone and put a voltmeter under the dash?
Roy
1965 Suburban
Old 01-29-2011, 12:11 PM   #4
protrash64
protrash64's Avatar
Roy
I ended up making a two gauge pod for 2 5/8'' gauges and ran an old volt I had laying around and added a 2 5/8'' tach I found at the parts store. I need to fix my speedo so I will be tearing apart my cluster at some point.
Old 01-28-2011, 08:32 PM   #5
DPowers
One foot in front of the other
DPowers's Avatar
Might try these:
http://www.jcwhitney.com/chrome-2-ra...wx?filterid=j1
http://www.jcwhitney.com/illuminated...wx?filterid=j1
I played around some with the tach-
http://67-72chevytrucks.com/vboard/s...95#post4305395
DPowers is offline   Reply With Quote
Old 01-28-2011, 09:55 PM   #6
protrash64
protrash64's Avatar
That tach looks good DPowers.....I have an old NAPA tach with 6K that would be perfect but it doesn't work Didn't feel like trying to get it fixed.
Old 01-29-2011, 08:32 PM   #7
DPowers
DPowers's Avatar
Welll- you could send it to me then....
Old 01-29-2011, 08:39 PM   #8
protrash64
protrash64's Avatar
Why's that?? You know how to fix it??
Old 01-29-2011, 08:42 PM   #9
DPowers
DPowers's Avatar
Have no idea- but willing to take alook at it and try.
Old 01-29-2011, 07:09 AM   #10
RoyL
RoyL's Avatar
PO had put in the same tach as you . . . It looks like one from Making Waves brand in JC Whitney . . . where'd you get yours? It fits good in there.
Roy
1965 Suburban
Old 01-29-2011, 08:31 PM   #11
DPowers
DPowers's Avatar
Roy
JC Whitney as well- around $40.00. And you dont' have to cut up the dash itself. Just the one backing plate.
http://www.persh.org/pickup/TachDash.htm
Old 01-29-2011, 10:48 PM   #12
RoyL
RoyL's Avatar
Roy
nice write-up,thx. Now I know what's behind there now.
Think I'm gonna mount a small volt meter under the dash somewhere.
Roy
1965 Suburban
Old 01-30-2011, 12:51 AM   #13
Rich 5150 69
Rich 5150 69's Avatar
Find yourself a mid eighties GM car with the voltmeter, remove it, take it home and dismantle it by separating the movement from the face, doing the same to your original, install the eighties onto your original face, install into dash pod, thats how they are doing this on the chevelles, I have`nt done it yet but am looking into it.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-02-2011, 11:53 AM   #14
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
From the 1963 GMC Accessories Book. Chevrolet Accessories book had it listed as well.
Old 03-02-2011, 05:31 PM   #15
kieth
kieth's Avatar
I just bought a NOS Bat-O-Meter and a sun tach (less sender) I am in the middle of refurbing a 66 gmc dash and I think this will make it look a lot better.
I am trying to use chrome paint to finish it off will advise how it works and looks after everything is finished. Company wanted $200.00 to vacuum chrome it but I think I can do is by soda blasting the plastic, primering it, painting with chrome paint and then clearing it. Worst case I have to send it to them to redo it. Kieth
kieth is offline   Reply With Quote
Old 03-03-2011, 12:13 AM   #16
RoyL
RoyL's Avatar
Kieth,
Cool, where you gonna mount the Bat-o-meter?
Roy
1965 Suburban
Old 03-03-2011, 10:27 AM   #17
kieth
kieth's Avatar
Kieth,
Roy
I have a gmc as shown in the literature posted above. I will install the bat-o-meter in the LH opening and the tach in the RH opening. Or vis versa depending on which looks better. Kieth
Old 05-21-2013, 03:44 PM   #18
kieth
kieth's Avatar
Kieth,
Roy
JUST A LITTLE UPDATE:
FINAL RENDITION INSTALLED BATOMETER AND SUN TACH 66 GMC....
http://kieth.smugmug.com/Trucks/66-G...WmmMg&lb=1&s=A
IN THE TRUCK:
http://kieth.smugmug.com/Trucks/66-G...PBQ7f&lb=1&s=A
Old 08-12-2013, 08:21 AM   #19
earl84
I went to a junk yard and got the volt meter, have it installed in the cluster cutout thing and ready to install, but how do you hook up the wiring harness to the voltmeter? Did you cut the factory plug and install ring terminals? Any pictures? This is a great writeup, and I tested my gauge before installing. Just hope it all works when I get it back together, haha.
earl84 is offline   Reply With Quote
Old 04-03-2011, 09:02 PM   #20
RoyL
RoyL's Avatar
Yeah, sometimes, if it ain't broke, don't fix it, works just fine . . .
1965 Suburban
Old 04-03-2011, 09:17 PM   #21
Rich 5150 69
Well there is some thruth to that, but if you`ve ever had a harness fire due to a amp gauge/voltage regulator you`ll never have another one. I lossed a harness in a `62 409 back in `69......man what a mess....
Old 04-10-2011, 06:34 AM   #22
RoyL
RoyL's Avatar
be sure to read this as well, shows a better way to retain the meter with tabs and clamp. Should be enough room for a hose clamp . . .
1965 Suburban
Old 04-10-2011, 08:07 AM   #23
SFTorange
SFTorange's Avatar
Hey Roy,
Could you post how you wired up the gauge? It's obviously pretty simple, but there were three studs on the back of the gauge and I wasn't sure exactly how to hook it up.
SFTorange is offline   Reply With Quote
Old 07-07-2012, 12:53 AM   #24
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I found this thread by searching the forums for using the original ammeter space and replacing with a Voltmeter.
Good job on this.
I had a bad dash fire back in 84/85 when I had my old 65 before.
I'm going through the wiring now, and all evidence points to the ammeter.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-07-2012, 12:36 PM   #25
61K10
61K10's Avatar
i did it kinda the same in my 60-63 gauge panel. wanted a vac gauge for the left side (my K10 has the vac brakes) but haven't found one yet that i liked. so i put a $9 volt gauge there temp. tack is an old dixo--didn't want a 8k but the price was right.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
