01-31-2011, 03:52 PM | #1 |
61 c10 Frontend
Im trying to find out some info on 60-66 c10's I just bout a 61 and I keep hearing that they did not have a coil spring front end until 63 but mine does.
Can someone tell me for sure. |
01-31-2011, 04:04 PM | #2 |
Re: 61 c10 Frontend
Are you sure you have a 61? Did you cross check the vin to make sure?
Posted via Mobile Device |
01-31-2011, 04:13 PM | #3 |
Re: 61 c10 Frontend
I checked the vin tag to the title and someone may have changed it long ago im not sure I have had alot of 67-72 and 73-87 trucks this is my first of this body style. did a 61 have coil springs in the front?
01-31-2011, 05:05 PM | #4 |
1962 C-10
Re: 61 c10 Frontend
61's did not come original with coil springs. 60-62's came with torsion bar front ends. Your truck may have been converted.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
01-31-2011, 05:41 PM | #5 |
Re: 61 c10 Frontend
have you looked up your VIN?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-31-2011, 05:44 PM | #6 |
Re: 61 c10 Frontend
Thanks for all the info, it still has drum brakes so im guessing it would be safe to order parts for a 63-72
01-31-2011, 06:03 PM | #7 |
1962 C-10
Re: 61 c10 Frontend
Any pics of the truck?
Someone may have switched the numbers and title.
01-31-2011, 07:16 PM | #8 |
Re: 61 c10 Frontend
I know that in not the correct grille for a 61
01-31-2011, 07:17 PM | #9 |
Re: 61 c10 Frontend
It makes since that the vin tag was changed best i can tell its could be a 63 titled as a 61
01-31-2011, 07:22 PM | #10 |
1962 C-10
Re: 61 c10 Frontend
That's exactly what happened. It's a '63.
02-01-2011, 01:34 AM | #11 |
60-66 Nut
Re: 61 c10 Frontend
I agree.
The grill is a '63 The fender emblems are '63 The hood is the '62-'66 And the front suspension is coil spring Does it have mechanical clutch operation or is it hydraulic?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 02-01-2011 at 01:36 AM. |
02-01-2011, 09:30 AM | #12 |
Senior Car Nut
Re: 61 c10 Frontend
another difference would be the frame itself. the 60-62 frame should look like this:
with a big X in the middle. the later frames don't have this X frame width is also different, at the rear, the frame rails on the 63-66 are 34 inches, outside to outside, the 60-62's are 42 inches.
Larry Last edited by fleetsidelarry; 02-01-2011 at 09:31 AM. |
02-02-2011, 12:13 AM | #13 |
Re: 61 c10 Frontend
I have not been under it other then strapping it down. Im sure its a its a 63. makes finding parts cheaper and easier for me. Thanks guys for all the info. Im sure I will have more questions as i go.
