Old 02-01-2011, 02:43 PM   #1
1LOW4X4
dual tanks working, but right side gauge not?
hey guys, i have dual tanks on my 85 c20. they are both full, and the left side gauge works fine. but when you switch it over to the passenger side the gauge just falls down and never moves, no matter the level of gas in the tank. both tanks actually pump fuel, just the right side gauge sucks.
am i lookin at pulling the tank?
heres left side-works fine
passenger tank, no workie.
1LOW4X4 is offline   Reply With Quote
Old 02-01-2011, 02:51 PM   #2
GMC Guy
GMC Guy's Avatar
Re: dual tanks working, but right side gauge not?
check your wires first. trace the sending unit wire for the gauge, all the way up to the connection from the circuit board to the gauge itself.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 02-01-2011, 02:52 PM   #3
dabels23
dabels23's Avatar
Sounds like a bad sending unit(in the tank) or a bad ground to that sending unit.
dabels23 is offline   Reply With Quote
Old 02-01-2011, 03:16 PM   #4
baclay9
I have found this is usually due to a bad ground on the sending unit.
baclay9 is offline   Reply With Quote
Old 02-01-2011, 04:17 PM   #5
Chevyman350
in my 1987 R30 it ended up being that the retaining clip for the float came off, and the ground was almost rubbed into 2 pieces (some how it got routed between the bed support and the frame.)
Chevyman350 is offline   Reply With Quote
Old 02-01-2011, 04:17 PM   #6
1LOW4X4
Thanks guys. So I'm assuming sendin unit is right there stuck in the tank?
Old 02-01-2011, 04:25 PM   #7
Hulk Will Smash
Hulk Will Smash's Avatar
My right side tank doesn't show on the gauge either, but rather than fall down it just keeps reading the left side. Definately not worth changing the sender, but once I "x" a few more to-dos off my list, I'm going to start tracing wires and see if it's something easy.
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
