02-03-2011, 01:44 PM | #1 |
Johnny Ca$h Cowboy Cadillac
Well . . . I went and did it. Bought a 1961 Chevy short stepside 4x4. The Vin indicates a C long bed stepside instead of K short stepside. The PO must have put this together one piece at a time. The hood is like a '62 with no eyebrows and a clear turn signal lights. The emblems on the front fenders is like the 1963 type (bowtie under 10). The emblems on the cowl side are like the 1962 (bowtie beside 10). The interior dash definately looks to be 1961 with eyebrows. The chassis is a 4wd without coils, year unknown. When I look at the pumpkins front and rear the front lookl like a DANA 44 and the rear looks like a chevy 12 bolt. All wheels have 6 lugs. The engine is a V-8 maybe 283 as it has no side motor mounts, only the front with a manual 4speed with the granny first and divorced transfer case. as it has no side motor mounts only the front. My question is were the 4wd units posi front and rear?
Sorry so long. |
02-03-2011, 02:07 PM | #2 |
Who Me?
Re: Johnny Ca$h Cowboy Cadillac
Have any pics of this project?
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-03-2011, 02:09 PM | #3 |
where is the eng mounted at the frt? then there must be mounting on either side of the b/housing
most of them had no posi at all. there would have been a rear axle posi option, but I doubt a frt one 4 wd of this vintage didn't have coils , just semi-elliptic frt and rear. chevy also had the ser # stamped in the frame(top) by the strg box sounds like you bought a box of parts assembled ron |
02-03-2011, 02:32 PM | #4 |
pics pics pics, would like to see how engine is mounted in the front.
02-03-2011, 02:37 PM | #5 |
Yes, I have some pics. Not sure how to post them yet.
I like More's Law 'If more is better, then too much is just right.' http://s1238.photobucket.com/albums/...20chevy%20k10/ 1971 Chevelle - sbc 350 TH350 1961 K10 - sbc 400 4 spd M/T short stepside |
02-03-2011, 04:45 PM | #6 |
Front engine mount
"" Engine ""
02-03-2011, 04:54 PM | #7 |
could be anything from a 283-350. it is newer than your truck though.
frt eng mount is correct. must be mounted at the b/housing look like a 44 ron |
02-03-2011, 11:17 PM | #8 |
Resistance is Futile
I agree with padresag on the engine. Heads have acc bolt holes so they would be late 60's-70's.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
02-04-2011, 12:14 AM | #9 |
Dana 44, and cant say what the engine is doesnt appear to be a 283
02-04-2011, 01:14 AM | #10 |
60-66 Nut
Yes the front differential is a closed knuckle Dana 44. The front motor mount would be consistent with a '60-'62 4x4. You have a hydraulic clutch as the '60-'62's had. The radiator is the '60-'62 style. It is impossible to tell from that pic, what size the engine is other than it is a small block. You'll have to get either casting numbers or the suffix code from the front passenger side of the block....behind the alternator.
It is not uncommon to find these trucks that have been assembled from several different trucks. Some guys are just better than others at making them look like they aren't pieced together.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 02-04-2011 at 01:14 AM. |
02-04-2011, 06:43 PM | #11 |
Thanks for all the info. This site is great. As soon as some of the snow melts i'll get some of those codes. We just had 16-18 inches of blizzard snow and now two more inches. Bad thing is that the daughter's Pontiac (low to the ground) is parked in front of the 4x4 so more snow digging before playing.
[IMG]""[/IMG]
