02-05-2011, 12:16 PM | #1 |
Two piece driveline?
Does anyone run a two piece drive line in a bagged AD? It would save from having to redo the cross member between the cab and the truck, as well as cutting a notch or tunnel in the cab. Crazy idea?
02-05-2011, 12:24 PM | #2 |
Re: Two piece driveline?
It's not crazy, it's been done by many people.........
ONE PIECE AT A TIME http://67-72chevytrucks.com/vboard/s...d.php?t=442320 My Build Thread |
02-05-2011, 02:21 PM | #3 |
Im also interested in this idea. Does anyone have any pics of this?
"Lifes to short to drive an ugly truck." Project 55 To Life http://67-72chevytrucks.com/vboard/s...d.php?t=432994 |
02-05-2011, 04:12 PM | #4 |
Stock big trucks came with 2 piece drive lines. In my 59 tf short bed I ran a granny four speed and 1 ton rear end with a two piece drive line for a number of years. I pulled it out of another truck so I don't know if they came that way or the drive line had been shortened. Also, lots of 60s gm autos ran them too. They work ok and will take a reasonable amount of abuse but I can tell you from experience a 63 Impala center bearing will not hold up to repeated abuse behind a 375 HP 396 and 4 speed trans. I always carried an extra and got pretty good at roadside replacement!
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 02-05-2011 at 04:13 PM. |
02-05-2011, 05:19 PM | #5 |
I think someone on here had some pics in their build thread, if I run across something I'll post up a link..................
ONE PIECE AT A TIME http://67-72chevytrucks.com/vboard/s...d.php?t=442320 My Build Thread Last edited by cap n crunch; 02-05-2011 at 05:20 PM. |
02-05-2011, 05:26 PM | #6 |
02-06-2011, 09:06 PM | #7 |
Not exactly what you're looking for, but I'm using the s10 2 piece driveshaft in my 49 on an s10 frame. It's been shortened to accomodate my motor position.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
02-07-2011, 11:28 AM | #8 |
Im far too abusive to my drivetrain to use a two piece driveshaft...
I would either do the tunnel, or raise the cab up a bit higher. |
02-07-2011, 04:02 PM | #9 |
Across the street from me there is a '61 Impala with a 500 hp big block and a two piece drive line. It's a pro touring car. He drives it hard, but I'm not sure that he's abusive.
02-07-2011, 04:20 PM | #10 | |
And in some cases it makes alot of sense.. for example, if i had a very long wheelbase car/truck and tried to run a single driveshaft, i could easily get harmonic vibration issues. but like cajundragger just said, these trucks have short enough wheelbases, with the engine far enough back, that we dont NEED two piece driveshafts. actually, if you were to have alot of suspension travel, be it from a custom 4x4 link setup, or from alot of airbag travel, you could actually get very large (undesirable) driveshaft angles from a two piece driveshaft setup. if this is just a cruiser, it doesnt matter.. a properly installed 2 piece will probably be perfectly silent and fine. if you do anything stupid like me (dragstrip, autoX, beating-on-it-like-a-16yr-old-for-kicks, etc) then i highly reccomend a 1piece driveshaft.. i suppose a really well built aftermarket 2 piece would be a possible solution, but the cost/benefit ratio just isnt there in my mind. Last edited by MrDude_1; 02-07-2011 at 04:21 PM. |
02-07-2011, 04:09 PM | #11 |
I'd bet he has the inland empire centersupport which is awesome and 1000 times better than stock.
The main draw back to a two piece is having a slip yoke on the rear shaft if your lowered. These trucks are so short tho I'd just put a 1 piece shaft in it. My truck lays running board and it wasn't that much of an intrusion into the cab floor to allow for the 1piece shaft. Posted via Mobile Device |
02-07-2011, 04:21 PM | #12 | |
Long live SLIM ------------------ At least try to buy American |
02-07-2011, 04:42 PM | #13 |
I am so against notching the cab that it is worth the risks/costs of a two piece for me right now. The lowest my truck will go fully aired out will leave the running boards 2 inches off the ground.
02-07-2011, 05:37 PM | #14 | |
this is how much my cab is notched- and I didnt need to do that much but I set everything up for when I want to run bigger wheels. |
02-07-2011, 05:44 PM | #15 |
oh and let me add.
Im not complete against 2 piece shafts. Im building a little truck right now that will be bagged and lay body and have a 2 piece driveshaft to save from cutting the floor as much because the truck has no space underneath it. but for this application I really can't see why it'd be necessary when its hard to get it right and these trucks have plently of room underneath them even when they are laid on the ground. |
02-07-2011, 06:00 PM | #16 |
I certainly appreciate your input. Thanks for the pic. It really is a small notch.
02-07-2011, 10:45 PM | #17 |
Moderator
GhostTown, I have my truck set up with a small notch in the back and mustang II front on airbags. My running boards set about 2-3" off the ground. I played around in my head with a 2 piece driveshaft for a long time but when I finally set the engine and trans in I discovered I only needed about 56 1/2" which is a very standard size. I threw the 2 piece idea out the window. All I had to do was notch that crossmember which was really easy with some 1/4" plate. Take a look:
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
02-07-2011, 11:36 PM | #18 |
Thanks Leevon. I'll discuss this further with the guy who's doing the work. The images everyone provided has really helped.
02-08-2011, 09:28 AM | #19 |
After studying your images further Leevon, it just occurred to me that you ARE NOT notching your cab, right?
That would be great if mine works out to be the same. |
02-09-2011, 08:54 PM | #20 |
Moderator
Right, it will need a little clearancing at the pinch weld on the firewall (maybe 1/2") and I need to knock the trailing arm crossmember down about the same but no other issues.
02-09-2011, 09:17 PM | #21 |
I took your images to the guy working on my truck and after some debate, it was decided to removed that factory cross member all together and just build a new one. Turns out I'll get lower than I thought.
Thanks for posting those Leevon. It really helped. |
