Old 02-06-2011, 04:28 PM   #1
jojoman
posi or no
i just took my rear end apart because i was driving and when i hit the brakes my truck was making this rumble noise in back shaking my bed well i thought it was my brakes nope my seal from the axles were worn out and the oil from the rear end got in my drums and making it my pads stick and not braking had to take everything apart well after all that my bro told me my rear end wasnt a posi so just wondering is it or not is a 10 bolt my truck a 87 so just let me knowName:  Picture 002.jpg
jojoman is offline   Reply With Quote
Old 02-06-2011, 05:52 PM   #2
joe231
joe231's Avatar
Re: posi or no
Not a posi
Just a regular open differential
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-07-2011, 12:12 AM   #3
jojoman
Re: posi or no
oh ok i was just in thought that all 87 came with posi then what can i get a posi off
Old 02-07-2011, 12:18 AM   #4
joe231
joe231's Avatar
Re: posi or no
a limited slip differential was an option. The factory Gov-lock posi is pretty weak. There is an aftermarket locker called a powertrax that can be installed with out removing the carrier therefore no ring and pinion set up required. they are @ the $350 price range. I'm not sure on the durability, but I would think they gotta be better than a Gov-lock
CHEVY ONLY
Old 02-07-2011, 04:23 PM   #5
silvereagle07
silvereagle07's Avatar
Re: posi or no
The powertrax unit is the unit that Stacey David installed in project Knuckle Buster on his show. Looked pretty simple. The other option is to build the entire rear end to install a limited slip differential/gears. You don't need a posi for the street in my opinion.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-07-2011, 07:54 PM   #6
thesickc10
Re: posi or no
you dont NEED it but it sure is fun!
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 02-07-2011, 08:27 PM   #7
68Timber
I know the pieces fit
68Timber's Avatar
Re: posi or no
I haven't used the Lock-Right unit from Powertrax yet, haven't needed one so far. But they are reputed to be strong - not as strong as a Detroit Locker, but far better than the G80. Plus, as mentioned previously, installing one doesn't require setting the gears up again - bolt on and go.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-07-2011, 08:35 PM   #8
jojoman
Re: posi or no
bolt on meaning that i take the cover off take the gears off and put the new one on just like that
Old 02-07-2011, 08:44 PM   #9
68Timber
68Timber's Avatar
Re: posi or no
The part of setting up a rear axle is getting a proper gear lash, or wear pattern between the ring and pinion set up so it will last. Like I said, I haven't done this, but the Lock-Right is advertised to be installed without disturbing the ring and pinion. So yeah, it's supposed to be a bolt-on locker.
Check here for more information - http://www.richmondgear.com/powertrax/lockright.html.
John
74 Honda Z50 build
