Old 02-08-2011, 11:28 PM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Dash Pad Removal???
Are the dash pads riveted on the ends? Can someone please explain the R+R on a dash pad removal procedure? Thanks for the reply's...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-08-2011, 11:34 PM   #2
67chevy1series
67chevy1series's Avatar
Re: Dash Pad Removal???
they are just screwed/bolted there are the 4 screws and then there is 5 or 6 bolts (they are the same bolts as the emblems for the fenders) the old ones are a pita to pull off for some reason! the new ones go on good and come off good
67chevy1series is offline   Reply With Quote
Old 02-08-2011, 11:42 PM   #3
Ironangel
Ironangel's Avatar
Right on, and thanks for the quick reply Rick! Im headed back out to the shop! I got the four screws out no problem, when I pulled on the old pad that seemed to be stuck or glued, the end broke off and exposed what appeared to be a rivet! I think Ill grind the end screw heads to free the steel straps through the old pad. Sound feasible? I have a new pad to reinstall. Thanks Longhorn for the reply!
"Two Seventy Two's"
02 3/4 ton Express
Old 02-08-2011, 11:45 PM   #4
67chevy1series
it does just be car ful with your dash! good luck and take pics to! i took mine out but still need to buy a red one and install ....your welcome buddy!
Old 02-09-2011, 12:04 AM   #5
cheyenne shortstep
cheyenne shortstep's Avatar
I would suggest following Longhorn Mans advice, sounds like he's actually done it once or ten times.
cheyenne shortstep is offline   Reply With Quote
Old 02-09-2011, 12:12 AM   #6
67chevy1series
yes long horns man is nice ......man i even sound like i dont know what i am doing??......
Old 02-09-2011, 12:46 AM   #7
sameyrasmea72
sameyrasmea72's Avatar
If your not wanting to take your whole dash pad apart right now there is another option. If your old pad is worhtless you can rip off all the old padding and there will two strips of metal. The top strip has the 7 bolts in it. You can use tin snips to cut away the bulk of the metal. Then use a sawsall to cut the 7 bolts. Just don.t cut your dash You might scratch it abit but the new pad will cover it.
This is sort of a temporary solution if you are not wanting to take every thing apart right now. The four screws on the outside of the new pad will hold it in place til you get ready to do the 7 bolts or the ones you cant reach now.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 02-09-2011, 01:36 AM   #8
Ironangel
Ironangel's Avatar
Hey Thanks for the reply's you guy's! That "suck factor" just shot out of sight! I closed the shop and will dismantle the whole dash tomorrow. This did resolve a decision to paint the dash or not. Ill go ahead and look into sliding that steering column forward a bit while everything's apart. Im going to have a screw driver or a wrench on every bolt and screw on this old girl...whether I want to or not! Ill post pics tomorrow...Thanks again
"Two Seventy Two's"
02 3/4 ton Express
Old 02-08-2011, 11:42 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
count on pulling the inst panel, radio, center A/C vent (if equipped) and the glove box liner. It can probably be done without removing all this, but you won't want to do it that way.
Old 02-09-2011, 12:10 AM   #10
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
As Longhorn suggested, you'll be a lot further ahead taking some items out of your way. It can be done but is not easy. The bolts stick through to the backside of the dash... Some are relatively easy to get to, some aren't. Stick your arm up behind the dash and you should be able to feel them... There is 1 at either end and then 4 or 5 in between. The ones behind the cluster and above the radio can be a PITA.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 02-09-2011, 12:13 AM   #11
67chevy1series
my biggest problems were the ones on both ends!
Old 02-09-2011, 12:33 AM   #12
VA72C10
VA72C10
VA72C10's Avatar
Just to add....some of the trucks I had where people switched them out they used adhesive and no bolts at all due to the hard nature of the installation...so I'd check to see if it will come up easily...
....and depending on how much you're doing on the interior put it back on before you put your glovebox, radio, and cluster in...
Old 02-09-2011, 03:31 AM   #13
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
A 1/4 socket set and extensions will help a lot..
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-09-2011, 05:58 AM   #14
cdowns
cdowns's Avatar
plus using a palm rachet makes it very easy to do
Old 02-09-2011, 06:02 PM   #15
Longhorn Man
I guessed I shoulda said it more like this...
if you try to do it without removing alll that stuff, it'll make you want to punch a nun in the face you'll be so ticked off.
I gotta say, I DO like the sawzall idea.
Old 02-09-2011, 06:54 PM   #16
kev2809
low n' slo
kev2809's Avatar
i used my cutoff wheel..just be careful!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-09-2011, 06:58 PM   #17
leddzepp
Moderator
leddzepp's Avatar
a gear wrench works great too
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-09-2011, 08:33 PM   #18
CORSAIR
CORSAIR's Avatar
Wow I didn't know that there was so many was to screw in a light bulb!!
"The Can't Family Lives Across The Street"
CORSAIR is offline   Reply With Quote
