03-14-2010, 05:48 PM | #1 |
Polishing Stock Grill - Before & After Pics
I finally got a day of warm weather so I got to finish the grill on the 71.
All of the moldings are finished now and the truck gets home from paint on Wednesday. Last edited by augie; 05-05-2011 at 02:11 PM. |
03-14-2010, 08:00 PM | #2 |
Re: Grill Before & After Pics
I stripped the anodizing off with a mix of sodium hydroxide and water.
I popped out the dents and sanded out the pits then buffed all of the areas that were going to be shiny and masked off the black area. The black is SEM trim paint. I brushed the lower apron section just to make it sort of a "Three Tone" effect. Then I applied an automotive clear coat to the whole thing and applied the trim black again to break the gloss. Normally, I would have Re-anodized the thing but I couldn't find any place that had the facility to do it. So, instead I had to clear coat it. It should hold up for a while because I plan to keep it covered and garaged. |
03-20-2010, 12:01 AM | #3 |
Your grill looks great!! Real nice work!
Not to hijack your thread, but throwing in my .02 here for another option. I use Krylon "Dull Aluminum" a lot on my GM resto's.. It works well on grills, rally wheels, etc., and is the closest thing I've found without buying the correct but super-expensive "Argent Silver". I hardly ever see it in stores, but I keep a case here directly from Krylon at about $3.15 a can. For the grills and some of the other stuff, you'll need to follow with a clear coat as well.
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8 '74 Trans Am 400, '80 Trans Am Indy Pace Car Mercedes AMG S55, SLK230 Kompressor, GL450 '96 Dodge Indy Ram Official Indy Truck '99 Porsche 911 Carrera |
03-15-2010, 10:00 AM | #4 |
03-15-2010, 10:02 AM | #5 |
The shiny parts were sanded with 400 wet and then Scotch Bright wheel. Black cutting compound on a Denim Wheel followed with red and a cotton wheel.
03-17-2010, 10:48 AM | #6 | |
WARNING! THIS STUFF WILL BURN YOUR SKIN AND CAN CAUSE BLINDNESS IF IT GETS IN YOUR EYES. Wear protective clothing, gloves and eye were!! Mix 1 part lye crystals to 20 parts water in a plastic spray bottle and apply to the grill. Allow it to sit for 10 minutes and scour with an abrasive pad (Scotch-Brite Red works well). Rinse with water and repeat the procedure if necessary. |
03-20-2010, 12:01 AM | #7 | |
http://www.caswellplating.com/buffs/ds.html |
