Old 02-11-2011, 03:27 PM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Firewall hole? Whats it for
What is this hole for and where can I get this grommet
(its between the steering column and gas pedal)
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 02-11-2011, 03:32 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Firewall hole? Whats it for
Looks like the clutch linkage hole.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 02-11-2011, 03:39 PM   #3
myoldchevytruck
well it was an I-6 with a three on the tree so that make sense. thanks
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 02-11-2011, 04:22 PM   #4
cdowns
cdowns's Avatar
i'd measurethe diameter of the hole and go to lowes or ace hardware boat supply stores too and look for the right size hole plug as the cheap way to close it up//dont ferget to bring a tape measure with you
Old 02-11-2011, 06:30 PM   #5
vectorit
What?
vectorit's Avatar
Clutch linkage.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-11-2011, 10:10 PM   #6
Dynomutt
Dynomutt's Avatar
Well I was trying to post a picture for you to see how the factory covered it but I can't post a pic. Not sure if the site has something going on or not.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 02-11-2011, 09:43 PM   #7
hayhauler71
hayhauler71's Avatar
If you had an auto trans it would have a metal plate over that hole
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 02-12-2011, 02:06 AM   #8
70chevykidd
70chevykidd's Avatar
When I got mine that hole was used to run the mechanical oil line through an it had a grommet on it surprisingly lol
70chevykidd is offline   Reply With Quote
Old 02-12-2011, 07:33 AM   #9
OhioDan
OhioDan's Avatar
Here's a pic showing what is supposed to be there?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
