![]() Join Date: Feb 2011
Will this fit a 3/4 ton C20?
http://www.brotherstrucks.com/prodin...=LRL6372&qty=1
Are all leaf springs the same dimensions? |
Re: Will this fit a 3/4 ton C20?
Best way to find out is call and ask. I would think they would though....
1969 Chevy c20(Miss Hackjob) |
yes they are 2 1/4" wide on c10 and 20 they will fit.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I have a 1969 c20 longhorn. My leaf springs are 2.5" wide.
its all about the +6 inches
even thoguh your longhorn is built as a 3/4 ton, it is built on the one ton frame, and they gave it one ton sized springs.
I called and asked, they will fit 1/2 ton trucks only. Does anyone know of lowering leaf springs for the 3/4 ton?
1971 C20 Longhorn Custom Camper |
67-72 parts collector,…
![]() Join Date: Nov 2002
How low are you wanting to go?
Have you considered a "flip kit"?
Only four or five inches. I've looked at it pretty thoroughly and it would be totally slammed if I did that.
I replied in your other thread.
www.PerformanceOnLine.com sells them for C20 trucks.
How's the ride quality if you remove some leafs? Bouncy?
I removed the two smallest leafs and it rides a lot better, it is not bouncy at all. I think it softened it up just enough for the shock absorbers to actually absorb bumps. The back end sits 1" lower. I haven't put any weight in the back of the truck yet, I would imagine that if I try to haul something heavy it will probably sag.
I called Performance Online yesterday to ask how their leaf springs can fit both a C10 and C20. They thanked me for catching their error and are custom building me a set of 3/4 ton 5"drop leaf springs for the normal price. I highly recommended them.
