Old 02-13-2011, 10:40 PM   #1
65GMCFirstride
65GMCFirstride's Avatar
Smile Frame Dimensions - Is this a surprise?
My son and I are restoring a 65 GMC Truck. I noticed the front bumper bolts were about an inch from their original holes when we bought it. Everything else seemed straight (door gaps, bed and cab alignment, etc.). It drives great...straight down the road. We have it apart now and you can visually see the front frame rails are pushed to the passenger side a bit. So, I decided to measure it. The measurements show the front frame rails are out the most, but all dimensions are off a bit. I am taking to the frame specialist soon to let them do a more scientific analysis, but I am interesting in knowing "Is it common that the dimensions are .25 to.5" off on a 46 year old truck or is my frame Whacked?" Thanks!
65GMCFirstride is offline   Reply With Quote
Old 02-13-2011, 11:03 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Frame Dimensions - Is this a surprise?
From what I`ve read 1/8 th to 1/4 was pretty much the norm, .5 was a stretch, may have been bumped or pulled out of ditch at one point in its life, watch a lot of new trucks going down the road espescially fords seem to be the worst for dog tracking...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-15-2011, 10:47 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Mine is off by a small amount also.
On mine, if you pull from (A) to (C) there's a 1/2" difference in the opposite direction.
I was just searching to see where here in Portland to get this checked/fixed, and your thread popped up.
Great job with the drawing above.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-16-2011, 12:15 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
Yes, the tolerances were about that to begin with, and then add several decades of use. Just be glad it's not an X body...ugh, dealing with first and second generation Chevy IIs and Novas, I'm happy if things are within 0.625".
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
