Old 03-15-2003, 10:30 PM   #1
ScottH
ScottH's Avatar
Front end differences 72 vs 78
Can anyone tell me what differences there are between a 72 front suspension / steering and the same from a 78 suburban 2wd? I'm considering installing an entire cross member (suspension and steering) from a 78 suburban in 69 C10, but may have a choice to use a 72 instead.
Any info is appreciated. Thanks.
ScottH is offline   Reply With Quote
Old 03-15-2003, 11:05 PM   #2
Xzavior240
Xzavior240's Avatar
I asked a similar question a few months ago about my 71 and 79 which is similar in just about every way here. the crossmember will interchange completely you may have to drill some holes but as far as length and everything its a perfect match. I had the motor out of the 79 in my 71 and the headers wouldnt bolt up because they hit the 71 crossmember I decided its cheaper to buy headers for a 71 well maybe not cheaper but easier. but I believe if you use part of it you have to use it all not just part of it, I may be wrong on that but I think thats what I was told. the only real difference that I remember is the frame is longer from front to back on the 78 then it is on the 72. front crossmember should be almost if not completely just a bolt on deal. and a day or so of wrenching drinking and a whole lot of cussing.
71 chevy C10 LWB 2WD runs and everything
79 chevy 1/2 ton Big Ten silverado gonna part it out since it left me walking.
69 f100 real good shape with lots of go go juice
89 plymouth reliant (daily driver)
86 thunderbird sitting in the weeds almost covered (anyone need parts?)
WWW.xschunkofthenet.freeservers.com
nothing there I promise
" tell me I'm a sinner I got news for you. I spoke to god this morning and he dont like you" OZZY
Xzavior240 is offline   Reply With Quote
Old 03-15-2003, 11:07 PM   #3
Xzavior240
Xzavior240's Avatar
it should bolt into the 69 as well since the 69 is the same as the 72 sorry forgot to add that
Old 03-15-2003, 11:12 PM   #4
ScottH
ScottH's Avatar
Thanks! the info is appreciated....time for a beer run
Old 03-15-2003, 11:14 PM   #5
Xzavior240
Xzavior240's Avatar
hey swing by here on your way out . I could use one of those too
