Old 02-14-2011, 11:18 PM   #1
dbaer
dbaer's Avatar
Floating 71 steering
My son and I have a 71 k10 for his first truck. It has a 4" lift and 35's but seems to be pretty sloppy in the steering. What are the most suspect things to check?
dbaer is offline   Reply With Quote
Old 02-15-2011, 12:59 AM   #2
skoffice
skoffice's Avatar
Re: Floating 71 steering
I just messed around with my '71 last weekend. First thing I would check is the tie rod ends and drag link. I put in new ball joints and built a new drag link and that solved about 70% of my steering slop. Next thing I will do are the tie rod ends, they still make noise so I know that's where the remainder of my slop is, but they're $75 each, so I'll probably just go with 1 ton ends and a beefy DOM bar for that kind of cash. I'm also considering cutting the rag joint out and putting in a borgeson joint. With a steering stabilizer to dampen the steering, I don't think a solid steering box connection would hurt any. Have you considered going with crossover steering? With those bigger tires and lift, it might help by having a flatter drag link that goes all the way across. Sounds like you might be borderline for that though, might not be necessary. If you have the stock steering arm on the driver side knuckle, it may help to have a raised one if you don't already. That's my .02 The best thing I could recommend is get under there and you or your son turn the wheel back and forth, while the other checks underneath for anything obviously loose. Don't be afraid to put your hand on a tie rod end or drag link, sometimes you can feel something that you can't visually see.
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 02-15-2011, 10:53 AM   #3
Does it have a raised steering arm to compensate for the lift? They bump steer real bad without it.
Old 02-15-2011, 11:03 AM   #4
67swb72klb
67swb72klb's Avatar
check the toe
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-15-2011, 02:45 PM   #5
dbaer
dbaer's Avatar
It has a raised arm for the lift. The toe is an interesting suggestion. Is it a matter of degrees or a measurement, and what should it be ?
Old 02-15-2011, 08:16 PM   #6
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Straight up or if anything 1/16" out from front of wheel to back of wheel works best. Then it'll have even tire wear and the front will always help to pull into a corner instead of fighting the outside.
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 02-15-2011, 09:52 PM   #7
67swb72klb
67swb72klb's Avatar
i was told 1/16 in thats how i roll mine
Old 02-15-2011, 10:44 PM   #8
skoffice
skoffice's Avatar
I run 1/16 in as well. Just cuz I think about forward movement would want to "pull" the wheels away from eachother, I visualize it as a sort of preload for bearing tolerances, tire movement etc.
Old 02-15-2011, 11:43 PM   #9
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
my steering box was loose when i bought my jimmy. thats why i got it so cheap. the po thought the everything was shot. 1 bolt was gone and one was hanging from the hole in the frame. after i bought it i chased the threads and replaced the bolts in his driveway before i drove it home. check the simple stuff first. theres only so much stuff between the steering wheel and the pavement.
mustardjimmy71 is offline   Reply With Quote
