02-14-2011, 11:51 PM | #1 |
Tilt-Not Mine
-Scott- |
02-14-2011, 11:54 PM | #2 |
Still Learning
Re: Tilt-Not Mine
Can anyone tell from the pics if this is a real deal truck tilt? It says there is something broken too what about that?
02-15-2011, 03:53 AM | #3 |
Always on the hunt...
Re: Tilt-Not Mine
Looks like it could be a real truck column, but if wanting to use it as an auto column shift tilt, at minimum it would need a replacement tilt only shift bowl (pic below) and a new indicator lens and lens housing. If this was being used in a manual or floor shift auto truck the lower shift arm lever may have also been cut off, if that is the case it should just be modified into a floor shift tilt. Mel
02-14-2011, 11:56 PM | #4 |
Re: Tilt-Not Mine
I can't tell for sure. Looks a little long to me. One of the shift lever retainer pin holes is broke.
-Scott- Last edited by sjarrett71; 02-14-2011 at 11:59 PM. |
02-15-2011, 12:13 AM | #5 |
Moderator
Re: Tilt-Not Mine
I would pass it over...
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
02-15-2011, 12:27 AM | #6 |
VA72C10
Re: Tilt-Not Mine
Looking for a 67-72 swb or blazer project in or around VA. |
02-15-2011, 09:49 AM | #7 |
Re: Tilt-Not Mine
Like I said, not mine. I just thought it was cheap enough to post up the link.
-Scott- |
