03-16-2003, 10:13 AM | #1 |
another engine swap question.....need som expertise
I am pulling the inline 6 out of the 72 this morning along with the 3 speed tranny. My question is this...... If I was to get the V8 mounts, move them up to the proper spot and put my 350 there, will I have problems hooking up my driveshaft and shift linkages? I was speaking with a very wise mechanic last night and he figes that it's only about 3/4" that it will move up and there shouldn't be any problems with this. I always thought that you would need a longer driveshaft to do this.
I could realy use your guys help on this because if i can put the 350 up farther so the HEI will clear the firewall some more, then I'm all for it. I just don't want to get into a whole bunch more work here. Many thanks
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
03-16-2003, 10:28 AM | #2 |
Fabricate till you "puke"
Your engine/ trans will move foward 3 1/2"(plus or minus 1/8") from I 6 to sb V8 position, so the front half of the d shaft will be that much too short. you will also need to replace the bell crossmember, or just run an auto crossmember under the stick trans(I6, & V8 bell crossmembers are different).Im not sure how that will affect the column linkage,as i ran a floor shifter in my stick trucks. good luck,crazyL
03-16-2003, 12:36 PM | #3 |
the saginaw 3-speed and bellhousing are the same leght as a th-350 long shaft tranny, hope this helps in your qeust
69 chevy short wide box project 70 GMC jimmy project |
03-16-2003, 01:06 PM | #4 |
Formerly yellow72custom
I would just go get a driveshaft out of a V8/3spd truck from the junkyard. BTW, i have seen V8's with HEI in the I6 position, the distributor does fit, but it is awful close to the firewall. If your broke a motor mount somehow, the HEI cap would proably get crushed when you revved the motor.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
03-16-2003, 04:51 PM | #5 |
The sag 3spd+bell are the same lenght as a SHORT 350th. The HEI dist do clear, but are tight in I 6 position on the sb. the cap & rotor need to be off, to get the dist in /out of the eng. here are a few pics..... http://community.webshots.com/user/hotrodhorn you cant see the HEI, but its in there!
03-16-2003, 06:05 PM | #6 |
maybe thats what i did on the first pickup i had, when i did the swap. moved the engine to the forward mounts and used the long shaft trans so i wouldn't have to mess with the driveline leght.
03-16-2003, 06:18 PM | #7 |
Seasonal Poster
mine is a 350 on the I-6 mounts...I didnt do the swap myself, the guy before did, but i wish that he would have done it right, because it is pretty tight at the dist. but not all that bad. The i dont like is that the fan is so far back its not really under the shroud
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
03-16-2003, 06:20 PM | #8 |
Seasonal Poster
heres a pic
03-16-2003, 06:23 PM | #9 |
Methinks that would work John! The short 350t is a 6" tail, & the med lenght is 9".......there is actually another lenght(12"tail if I remember it right). At any rate, the longer trans would get you close enough for driveline lenght with the eng in v8 position & the I 6 shaft.......more than 1 way to "skin a cat" crazyl
03-16-2003, 06:26 PM | #10 |
on the nose end, I use a 73 up waterpump, pulleys & acc to get the fan close enough to the rad without a 5" spacer
03-16-2003, 06:29 PM | #11 |
its all about the +6 inches
Or a 4X4 V-8 shroud would do the trick with the short pump.
