Old 02-17-2011, 07:40 PM   #1
mjo8585
mjo8585's Avatar
bed removal ?'s for a first time restore
hey I am just starting my restore on my '68 lwb chevy 2wd. I think I'm going to start with the box removal first. Any help on what to expect or any tricks you all have would be swell. thanks again!!
mjo8585 is offline   Reply With Quote
Old 02-17-2011, 07:55 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: bed removal ?'s for a first time restore
I leave the tail gate on then put 4 staps to the corners and lift it with the engine hoist...buat 4 of your buddies and some beer works well too....
just pull the bolts out and unplug the tail lights
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-17-2011, 09:00 PM   #3
Jerry Jones
Happy Camper
Jerry Jones's Avatar
For guys and one lady. Pull the bolts, disconnect wiring, 4 guys lift bed and one lady drives truck out from underneath.
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 02-17-2011, 09:38 PM   #4
67chevy1series
67chevy1series's Avatar
i thought it was four guys and a little boy! right rene?
67chevy1series is offline   Reply With Quote
Old 02-17-2011, 09:59 PM   #5
turner16
also remember the guys at the cab end have to lift it higher over the tires
turner16 is offline   Reply With Quote
Old 02-17-2011, 10:24 PM   #6
68 SHORT-STEP'N
SLOW POKE
68 SHORT-STEP'N's Avatar
You guys might want to watch your FEET !!!
68 SHORT-BED-STEP-SIDE
piece by piece ,
day by day ,
I will restore this truck ,
before the 100th anniversary !!!
68 SHORT-STEP'N is offline   Reply With Quote
Old 02-17-2011, 10:31 PM   #7
trkfrk
trkfrk's Avatar
My dilemma was finding something to set the bed on after removing it from the frame. I ended up using four 20 gallon grease barrels with homemade dolly's so i could maneuver it around my garage.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 02-18-2011, 12:36 AM   #8
Mike J
vw guy & now c-10 guy
Mike J's Avatar
I built 4 saw horses, then cut/air chiseled the old bolts out, then had me and 3 friends lift it off- my long bed wasnt nearly as heavy as i thought it would be, it was pretty easy
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 02-18-2011, 07:17 AM   #9
turner16
I used Milk crates
Old 02-18-2011, 08:10 AM   #10
Jessechop
I just removed mine all by my lonesome and here is what I did.
#1 unbolt bed. I got real lucky and my trucker is super solid and 5 of the 8 bolts came out, 1 snapped and I was left with 2 that were spinning. I dont have a torch and my air compressor is dead. So I welded 3/8 nuts to the top of the bed bolts, wrench on the bottom and spin them right out from the top.
#2 unplug the taillight harness
#3 I ran a 4x4 under the bed rails over the wheel wells. Backed the truck under my chain falls and lifted it up, drove the truck out and lowered the bed onto a pair of saw horses
Jessechop is offline   Reply With Quote
Old 02-18-2011, 08:54 AM   #11
cdowns
cdowns's Avatar
i like to grind the heads off the bolts soas not to damage the square holes holding the bolts// i just lift with engine hoist and roll the bed off. it's a bit easier to do with the wheels removed
Old 02-18-2011, 07:46 PM   #12
turner16
Last summer I removed the 8 foot bed from my 80 gmc and flipped it over then back over again all by my self!!! should have taken pictures, it was a feat of engineering!
I only used an engine crane and 8 milk crates.
Old 02-18-2011, 07:51 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Old 02-19-2011, 10:49 PM   #14
mjo8585
mjo8585's Avatar
oh man this is a great help guys. I just started today and I attempted to loosen 4 bolts. needle to say, it wasn't happening. its a wood bed so the carriage bolts heads just spin. not a big deal, it'll just take a little elbow grease. Thanks again for all the help!!
Old 02-19-2011, 10:58 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
If the bolts (in a steel bed floor) don't come out fairly easily,... I always cut them.
This saves any damage to the "square" hole in the bed floor.
The I reinstall it with a new set of bed bolts with some anti-seize on the bolt threads.
Keith
Convert to disc brakes.
Old 02-20-2011, 12:57 AM   #16
AirSpeed
AirSpeed's Avatar
If the bed is sitting correctly on the frame, you may want to mark the bed and frame underneath to make realigning it a lot faster. I learned this the hard way, I was alone when I put my bed back on and getting it back in position by myself was a pain in the butt! Before I removed it next time, I scribed some lines underneath and it went on a lot faster the next time. A few of the nuts were rusted so when I tried to loosen them up the head turned on the carriage bolts, I ended up tack welding the heads to the bed so i could take the nut off. After I got them off I ground off the tack weld and removed the bolt. Once it was out I squared up the hole with some weld so the new carriage bolts wouldnt spin. I used stainless steel bolts when I bolted back on.
I had no help removing my bed so I jacked up each corner and used milk crates to set it on, I then just pulled the truck forward. I did the reverse to put it back on.
Goof luck! It's really a pretty easy job.
AirSpeed is offline   Reply With Quote
