Old 02-17-2011, 07:47 PM   #1
ramey
71' Custom 10 (ole blue)
ramey's Avatar
Cool Is there anyway to level my truck
I was wondering if anyone made a level kit for our trucks, i wanna lower the rear alittle on my 69
GM Goodwrench 350
Turbo 350 Transmission
ramey is offline   Reply With Quote
Old 02-17-2011, 07:53 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Is there anyway to level my truck
new u bolts and spacer blocks will do the trick
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-17-2011, 07:55 PM   #3
ramey
ramey's Avatar
Cool Re: Is there anyway to level my truck
where can i get spacer blocks?
GM Goodwrench 350
Old 02-17-2011, 08:58 PM   #4
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
I think cpp do them, here's some at Autozone
http://www.autozone.com/autozone/cat...questid=218372
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 02-17-2011, 09:03 PM   #5
Hottrucks
Hottrucks's Avatar
I just saw them in speedway too depending on how high they where from like $11 to 18
cheap!!
Old 02-17-2011, 09:33 PM   #6
FL71C10
What impact do lowering blocks have on cargo capacity?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 02-18-2011, 02:43 PM   #7
jimmydean
jimmydean's Avatar
Do those fit the trailing arm trucks? It says for leafs, I want to know before I get my hopes up.
<edit> Are the axle tubes the same size on the C20? I'll see if I can grab a measure at lunch off another truck at lunch, but figures I'd ask.
<edit2> Thanks Brad, I figured they might not work on trailing arms, but I'll check to make sure.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-18-2011, 01:06 PM   #8
wldcat10
wldcat10's Avatar
I was thinking of lowering the rear of my 1970 too, how much of a drop do I need for it to be level with my front end, 3 in? My truck is all stock right now, just want to be the rear to be level with front.
1970 CST/10 LWB 350
1984 Blazer
wldcat10 is offline   Reply With Quote
Old 02-18-2011, 01:21 PM   #9
clos69
Its Topless Season!!!!
clos69's Avatar
LMC illustrates that stock height 2wd trucks are 32in in the front and 34in in the rear when measured from the top of the wheel arc to level ground....so to answer your Q...you would need to drop the rear 2in to be level at 32in all around.
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 02-18-2011, 01:41 PM   #10
wldcat10
wldcat10's Avatar
Thanks for the help! Are these lowering kits easy to install? Or would I be better off just taking it somewhere to get done. I like price of the lowering kit, so it would be nice if I could do it myself.
1970 CST/10 LWB 350
1984 Blazer
Old 02-18-2011, 02:38 PM   #11
brad_man_72
the boat guy
brad_man_72's Avatar
be sure to get lowering blocks for a 67-72 chevy truck if you have a trailing arm setup. The generic lowering blocks won't "fit" with trailing arms. It's a pretty simple project ut sometimes those ubolts don't want to come loose and may require cutting.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-18-2011, 04:21 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
Here you go.
These are for trailing arms,...
http://www.stockcarproducts.com/trkarm1.htm
Keith
Convert to disc brakes.
Old 02-18-2011, 04:54 PM   #13
eightbanger
454 MAKES IT ROAR
Sorry about that JD, my bad, I should have checked the link before I posted it....
Not meaning to Hijack...Lolife, do you need to buy all that stuff Cast Shims, Pinion Shims? and what are they for?
Nigel.
No more pain.
Old 02-18-2011, 05:11 PM   #14
lolife99
lolife99's Avatar
The pinion shims are for "dialing-in" the pinion angle.
With a stock spring,... I would say no.
Every truck is different.
Keith
