02-17-2011, 09:46 PM | #1 |
Tot Roddin'
Those with factory tachs... check in!
I'm looking to see if someone can post a picture of where the tach wire comes through the firewall. I'm trying to determine which dimple is the 'correct' dimple as there are 4 to pick from depending on the options installed.
I "think" it's the 3rd from the bottom, but I want to make sure I'm selecting the correct one. Working on a project for my FIL. Please post a picture of your firewall. Thanks in advance guys! Nate
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
02-17-2011, 10:59 PM | #2 |
Hand Crafted C-10
Re: Those with factory tachs... check in!
Bump for ya~~ or should I say 'dimple'?
02-17-2011, 11:51 PM | #3 |
Speaking of the fil where are the pixs of his truck?
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
02-18-2011, 11:56 AM | #4 |
Tot Roddin'
bttt...
I have seen this thread, but I want to locate the exact dimple that would have been utilized for the tach wrie. http://www.67-72chevytrucks.com/vboa...+wire+firewall Is this the correct dimple??? More to come.
02-18-2011, 12:26 PM | #5 |
My dimple where I drilled my tach hole was exactly where the picture shows it to be. Not quite as deep as those in the picture. I used the dimple as a punch hole for the 3/4 bit. There was even a perforated hole in my firewall material to match this location.
02-18-2011, 07:30 PM | #6 |
Tot Roddin'
Thanks for the post.
What did you mean by 'not quite as deep?'
02-20-2011, 02:32 PM | #7 |
67-72 parts collector,…
Nate,... I posted in this thread,...
http://www.67-72chevytrucks.com/vboa...ad.php?t=43277 I should have posted here. Lot's of confusion on where the "original location" of the tach wire hole should be in the firewall. Since the 67-68 firewalls are different,... you have to address the 69-72 trucks only. I don't have a picture out of the assembly manual. Maybe someone else can reply.
02-20-2011, 04:26 PM | #8 |
Tot Roddin'
Bttt... Anyone?
Bueller,... Bueller?
02-20-2011, 04:49 PM | #9 |
The Older Generation
Re: tach wire ?
Here are two different ones. the first one is a '67-'68 six cyl and i think one of the cables shown is for a cable driven tach. The second one is '71 six & V-8. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-20-2011 at 05:14 PM. |
02-21-2011, 02:40 AM | #10 |
VA72C10
Great info!!!
Looking for a 67-72 swb or blazer project in or around VA. |
02-21-2011, 05:22 AM | #11 |
Words under my name
subscribed, good info in this!
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project. 2010 VW Golf, daily driver Wrench Rookie |
02-22-2011, 10:22 PM | #12 |
Tot Roddin'
Hey Leon... you don't by chance have UPC-1's diameter as it refers to the bottom of the picture posted above? Hole Dimensioning...
02-22-2011, 10:30 PM | #13 |
Nothing to see here.....
take it back what I said a few nights ago. I used the dimple that's opposite of the 1-5/8 mark on the ruler. I looked at several factory tach rigs before I drilled at that location. forgot what size I drilled though. I believe I drilled a full size less than the grommet on the harness.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
