Old 02-18-2011, 01:06 AM   #1
FL71C10
4 barrel manifold recommendation
What do you guys recommend for new 4 barrel manifold/carb combo. Truck is a 75 or 76 smog 350 with headers and 350 automatic. is the performer or torker a good Manifold?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 02-18-2011, 01:11 AM   #2
1low
Re: 4 barrel manifold recommendation
performer rpm is a good one. if ur on a budget the plain performer is on craigslist around here all the time for abot $50
1low is offline   Reply With Quote
Old 02-18-2011, 01:23 AM   #3
FL71C10
There's a performer 2101 for sale locally. Is thast the plain one? What the difference?
Old 02-26-2011, 08:59 PM   #4
blackedoutharley
x1000!
blackedoutharley is offline   Reply With Quote
Old 02-18-2011, 01:31 AM   #5
1low
ya the diffrence is the power range but without a cam your not guna do much but lose weight
Old 02-18-2011, 01:32 AM   #6
FL71C10
even over a 2 barrell?
Old 02-18-2011, 01:48 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I put a 2101 Performer on my pretty-much-stock 350 several years ago after my OEM intake cracked. Seems very similar to the stock manifold, no noticeable difference in power, driving, cold start.... I don't know the particulars but it's just an intake manifold, gets the job done but nothing fancy. Still have the Q-jet on it.
If you're coming from a 2-bbl carb to a four-bbl on a 2101, you will definitely get more power than with the 2-bbl.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-18-2011, 07:02 AM   #8
royo
royo's Avatar
I like the performer rpm air gap.
nickle and dime
royo is offline   Reply With Quote
Old 02-26-2011, 07:04 PM   #9
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
Originally Posted by royo View Post
i like the performer rpm air gap.
+1
Torrey72 is offline   Reply With Quote
Old 02-18-2011, 08:38 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's hard to beat an Edelbrock Performer 2101 manifold and Edelbrock 1406 carburetor for performance, mileage, and ease of install. My first hot rod part I ever bought was an Edelbrock Performer intake back in 1989 and I've had a lot of them since then on many vehicles.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-19-2011, 10:54 PM   #11
andyh1956
i know the dual plane intakes have made a come back, we had them in the '60s- edelbrock c3b was one, c3bx was another. one was a little taller than the other. but if you have your truck geared to let your engine rev then you owe it to your self to try a single plane intake. a day & night difference. i know the dyno numbers say more torque with a dual plane but if you try a single plane you will never go back. i like the old edelbrock torker, and weiand made one also, don't remember the name. i built a 350 with the edelbrock kit- cam, chain & gears and intake. it was a dog. slap a torker to it & it woke up. i changed a stock 454 to a torker & was like the other bank started firing! just what i like.
andy
andyh1956 is offline   Reply With Quote
Old 02-26-2011, 05:09 PM   #12
FL71C10
I found an edelbrock performer squarebore for sale on CL. Is that what I want? I know there's a square bore and a spreadbore. I don't know the difference.
Old 02-26-2011, 05:25 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Spread bore mounts a Quadrapuke style carb... big barrels in the back, and littles up front.
Squarebores mount the Edelbrock style carbs, and the Holley 1850, 4150/4160 type carbs. All 4 barrels are the same size.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-26-2011, 05:41 PM   #14
FL71C10
See, I learned somethng today! So if I want to go with an aftermarket carb, squarebore is what I want, right?
Thanks!
Old 02-26-2011, 05:23 PM   #15
GASoline71
GASoline71's Avatar
Single planes are good for high RPM. You will lose low end grunt with a single plane manifold. I had a Weiand Excellerator (single plane) on a street/strip car... great manifold for high RPM drag strip stuff.
One of the best dual plane manifolds on the market right now is the Edelbrock Performer RPM Air-gap.
Topped with a Holley carb of course...
Gary
Old 02-26-2011, 05:53 PM   #16
GASoline71
GASoline71's Avatar
Depends on what you plan on doing. If you are getting a squarebore style manifold then yes... you will need an squarebore carb. If you wanna run a stock Q-jet... you will need a spreadbore manifold or an adapter.
However... if you're lookin' to hook up all the smog stuff again. You will need a manifold that will take an EGR valve. Then you might have to run the stock carb.
Gary
Old 02-26-2011, 06:18 PM   #17
FL71C10
No, I'd pull all of the smog stuff off. Where is the EGR valve?
Old 02-27-2011, 12:50 AM   #18
Captainfab
60-66 Nut
The EGR valve is on the passenger side of the intake manifold, near the back corner of the carb. It is round with a vacuum line going to it.
