Old 02-18-2011, 12:50 PM   #1
revjim
How to remove gas tank...
Just being careful>>>
revjim is offline   Reply With Quote
Old 02-18-2011, 01:21 PM   #2
jimmydean
jimmydean's Avatar
Re: How to remove gas tank...
Drain it, unbolt it, pull real hard? I'll be doing my tank next weekend, that is my plan for removal.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-18-2011, 01:38 PM   #3
k1rodeoboater
ask again in 72 hrs....I'm gonna try to do my tank swap & install in the next 3 days.
k1rodeoboater is offline   Reply With Quote
Old 02-18-2011, 02:11 PM   #4
revjim
how do you drain it? siphon??
Old 02-18-2011, 02:17 PM   #5
timjt
I've taken a few out, but not on my truck YET.
Siphon it, then use a jack (transmission jack if you have one) to lower it enough to get to the fuel lines and anything connected on top or to close to the top to get to when its installed. Once its all unhooked you can lower all the way out. Super easy. On our cars and relatives newer truck I don't even take it out from under the car to change the fuel pump. Just leave it on the jack under the car, make the swap and jack it up.
Its an easy job, but make it easier and get someone to help you manuver it into place when you put it back in.
2001 silverado stolen by family
1983 short n wide custom deluxe SOLD
1985 silverado longbed 305 engine 700r4
OH NO! NOT ANOTHER LEARNING EXPERIENCE!!!
"Just because you can do it, doesn't mean that you should"
timjt is offline   Reply With Quote
Old 02-18-2011, 02:24 PM   #6
revjim
mine is in the CAB!
Old 02-18-2011, 02:30 PM   #7
timjt
haha ok, sorry.
Old 02-18-2011, 02:31 PM   #8
jimmydean
jimmydean's Avatar
If you don't have much fuel in it, you can use a bucket and just pull the hose off the bottom under the cab.
A few weeks after I got my truck, it stalled on the freeway on the way to work. I had a clog somewhere, so I drained the tank and replaced all the rubber fuel lines and blew out the hard lines with compressed air.
I used my Harbor Freight ball pump and siphoned what I could, then put a bucket under the cab and pulled the line off the tank from underneath. Worked out pretty well. You could just plug it, too.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-18-2011, 03:23 PM   #9
daverod
SSN 706
daverod's Avatar
Disconnect the power at the battery. I pull mine out ,gas spilled when I was removing it from behind the cab, then the old wires were right there and started shorting like crazy. I had the key off. I'm still alive.
daverod is offline   Reply With Quote
Old 02-18-2011, 05:34 PM   #10
revjim
GOT HER OUT...thanks guys!!!
