04-25-2002, 08:33 PM | #1 |
king $h!t
rims rims rims3/4
ok i just got a 79 gmc3/4 but hers were i fed up hardi got 35/12.50/15 but i need to get 35/12.50/16.5 but if any one knows if any one makes a 3/4 ton rim but is a 15 inch
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s |
04-25-2002, 09:08 PM | #2 |
Got 20's????
Measure your drums first. There are some 3/4's that 15's won't fit on because of the larger brakes.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
04-26-2002, 11:43 PM | #3 |
its all about the +6 inches
And many states have made them illegal. That is why you'll probably never find them.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-27-2002, 04:08 AM | #4 |
Hillbilly Hotrod
I take it this is a 4x4.
Places to get 15" 8 lug wheels. 4 Wheel Parts warehouse, where I got mine. 15x10" with 4 1/4" backspacing. $41ea. National tire and wheel. Tyres International. there are a bunch more sources. A 15" wheel will fit ANY 14 FF axle regardless of the brake size. And I have never heard of them being illegal. Now the front axle is another issue. You will have to grind the calipers and backing plate a little to clear the wheel. It took me about an hour to grind both sides on mine. ------------------ 78 K5 on 3/4 ton axles.
69 K5, .060 over 350/465/205. |
04-27-2002, 10:26 AM | #5 |
king $h!t
powermad is there any way to see your rims and get all the mesurments for the i may just have to give 4 wheel parts wholeselleres a call
04-27-2002, 09:52 PM | #6 |
i have 8 lug 15 on my 3/4 ton 4x4 also, there not illegal, and you can special order them anywere, and yes you will have to do some grinding on the calipers a little, the rears fit with no problems.....
04-28-2002, 01:38 AM | #7 |
Hillbilly Hotrod
The ones I got from 4WPWH are the TEC ones. 15x10 with 4 1/4" backspacing.
I ordered them on a Tuesday and they were on my door step on Friday. pic 1 pic 2 pic 3 rest of the pics 4WPW ------------------ 78 K5 on 3/4 ton axles. [This message has been edited by powermad (edited April 28, 2002).] [This message has been edited by powermad (edited April 28, 2002).]
04-29-2002, 05:42 PM | #8 |
You could just swap out the eight lug axles for five lug (: I'll take the rear off your hands if it's a junky ol' 14 bolt.
72' Camper Special,454,th350,np205,4.56 locker,dana44 with spool,13" of lift and 44" boggers.soon to be 23" with rear disc brakes |
