02-19-2011, 01:12 AM | #1 |
Chevys Kick A$$
Biggest amp I can run with 4gauge wire
Just quick question. Tried searching threads had no luck lol. I am running 4gauge wiring kit in my truck any input on how many watts it can handle at the most? I already got a cap n am going to run a 15" sub in ported box was just wandering on how big of an amp I could use. Thanks for any advice or Input.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
02-19-2011, 01:32 AM | #2 |
Re: Biggest amp I can run with 4gauge wire
I read somewhere that 2kW is max on 4 ga and about 1kW on 6 ga.
Trevor "You already said spite" |
02-19-2011, 04:30 AM | #3 |
it's like this,, 4gauge can take about 2k if running full range,,
thats not the case here, you're running a sub,, a 15" in a ported box (gonna sound like crap, shoulda built a sealed box but no matter) a sub is low end bass and draws a lot of AMPS , double the amps that the amp would need if running at same watts into full range, cut the watts rating in half. as the amperage will be alot more driving a sub and it's power hungry bass low end.. |
02-19-2011, 03:30 PM | #4 |
>130dB Moderator
It depends gratly on the distance the wire is being run. If its under the seat of a reg. cab truck, its a whole 'nother story than by the gate of a Blazer...
Realistically and safely, you could run 1500wRMS/100a and be safe at most distances. I had a chart somewhere that had the measurements for wire/power/distance, but I can't fine it right now.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
02-20-2011, 03:41 PM | #5 |
The Engine Whisperer
If it was my vehicle and my system.. 4ga is used for up to 1000rms.
-Automatics win races, 6-speeds impress high school kids -Save a tree, support your local dragstrip. -"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui columbuscarsandcoffee.net and on Facebook |
02-20-2011, 06:52 PM | #6 |
Chevys Kick A$$
Sweet this is exactly what I was hoping to hear cause I think it was rated at like 1800 watts max but couldn't remember. Just wanted to see what would be a safe bet on what I could run. Thanks for all the input everyone.
02-20-2011, 11:33 PM | #7 |
what kind of amp is it?
02-21-2011, 10:49 AM | #8 |
I know I'm the minority, but better safe than sorry,,
if you run a high currant amp., all bets are off.. Also, make sure the connections are solid.. a connection with high resistance will melt a 0 gauge wires sheathing |
02-22-2011, 11:10 PM | #9 |
Chevys Kick A$$
Yea I already got the box and a couple different 15"s laying around that I can use. I haven't decided on an amp yet looking at the budget right now cause I gotta buy parts for the truck as well n pay bills before I buy the toys like stereo equipment haha. Just looking for something decent without breaking the bank that will sound good.
