Old 02-20-2011, 01:13 AM   #1
72gmcshorty
72gmcshorty's Avatar
Lower control arm....
Are the 2wd lower control arms all the same on the 67-72? I am not worried about the ball joints and cross shaft because i have new 1972 ones i will be installing. Truck and blazer are also the same correct?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 02-20-2011, 01:29 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lower control arm....
All the 67-72 1/2 control arms will interchange.
The 71-72 lower ball joint is different than the 67-70 lower ball joint.
Also,... the 3/4 ton lower control arms are different.
(the lower ball joint hole is a larger diameter)
Keith
Convert to disc brakes.
Old 02-20-2011, 01:37 AM   #3
72gmcshorty
so, i can put a new 72 ball joint into any 2wd lca with no issues? Correct?
1992 Gmc 2wd
Old 02-20-2011, 01:39 AM   #4
lolife99
lolife99's Avatar
Yes,... into any 67-72 lower control arm.
(excluding the 3/4-ton version if your balljoints are for a 1/2-ton truck)
Keith
Old 02-20-2011, 02:19 AM   #5
72gmcshorty
thank you!! Now to start the search
1992 Gmc 2wd
