Old 02-21-2011, 08:56 PM   #1
Doug_J
Doug_J's Avatar
Broken front cab bolt?
What is the best way to get the bolt out? it actully broke loose on the inside, I really dont wanna cut into the floor if it was in the back that would be fine but its the front one I was thinken about maybe cutting in from the side on the under side of the cab but Mud and crap will get caught up in their I would think any ideas or pics please.
Doug_J is offline   Reply With Quote
Old 02-21-2011, 10:14 PM   #2
DESTRO
Re: Broken front cab bolt?
What shape is the support in?? If it's rusty just cut it out and replace the whole support. If its nice you'll have to go in from the top.
DESTRO is offline   Reply With Quote
Old 02-21-2011, 10:54 PM   #3
Doug_J
Doug_J's Avatar
support is in good shape truck is solid other then all these damn bolts being rusted like no other. so how big of a hole do I have to cut in my floor and do i patch it back up when I get the body work done?
Old 02-21-2011, 11:01 PM   #4
chevymotocross
chevymotocross's Avatar
Happened to me.... on ALL my cab bolts lmao! I had to cut little access hole to get the rest out. Talk about a PITA!
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 02-21-2011, 11:03 PM   #5
SBTork
Garage wrench
SBTork's Avatar
I would used a 2" hole saw and measure a bunch of times before cutting. There is nothing worse than messing up and cutting a hole just a little bit off. Ask me how I know......
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-22-2011, 12:26 AM   #6
Doug_J
Doug_J's Avatar
So did you patch the hole up or leave it open so you have acesse to a nut? kinda woundering if it wouldnt be better that way so your not braking them off anymore..
Old 02-22-2011, 04:01 AM   #7
SBTork
Garage wrench
SBTork's Avatar
when I did mine I patched them up, but I welded all the nuts solid so they could not turn. Then put a TON of anti-seize on them. But, you could use body plugs too.
-Adam
Old 02-22-2011, 09:10 AM   #8
xrcr
I am going with the anti seize and plugs in the front holes, the rear holes I'm capping with sheet metal and silicone
xrcr is offline   Reply With Quote
